Im building a 383, and need some parts, preferrably reasonably priced.
-383 Crank, Prefer 2pc. Seal
-NEW 350 Bearings, full set
-NEW Freeze Plugs (Brass)
-Timing chain Set, double roller, Prefer New
-Pushrods, stock length, prefer new
-Oil Pump, Prefer Hi Vol. New
-8mm and UP Spark Plug Wires, Good shape
-Good Water Pump
-Gaskets, whole motor
-Cam, I dont know what I need, got suggestions?
Got anything else you think I need? Post!
Thanks.
I also have many parts for sale/Trade. Im located in Tampa Fl.
-Good Water Pump
Thanks.
-Good Water Pump
Thanks.
UpOriginally Posted by bradley23150
Im building a 383, and need some parts, preferrably reasonably priced.-383 Crank, Prefer 2pc. Seal
-Good Water Pump
Thanks.
Still need a crank? I have a new Scat crank but its 1 piece RMS. I also have bearings, Summit PNs CLE-CB663P (rods) and CLE-MS909P (mains).
Quote:
Im definately interested in the bearings.Originally Posted by MetalliCamaroRS
Still need a crank? I have a new Scat crank but its 1 piece RMS. I also have bearings, Summit PNs CLE-CB663P (rods) and CLE-MS909P (mains). Do they make adapters to fit the 1pc. into a 2pc. block?
If so, what do you want? What are your prices?
PM sent.
TIMMYS89GTA
close
no,a 1pc rear main seal crank won't fit in a 2 pc. seal block.Originally Posted by bradley23150
Im definately interested in the bearings.Do they make adapters to fit the 1pc. into a 2pc. block?
And you need to know what bearings you need before you just stuff anything in there.
I need Standard Sized bearings.
I no longer need:
Timing chain
Freeze Plugs
Plug Wires
Oil Pump
Need a 350 Crank, not 383, change of plan.
I no longer need:
Timing chain
Freeze Plugs
Plug Wires
Oil Pump
TIMMYS89GTA
close
Quote:
I no longer need:
Timing chain
Freeze Plugs
Plug Wires
Oil Pump
how do you know what size bearings you need if you still need a crank?Originally Posted by bradley23150
I need Standard Sized bearings.I no longer need:
Timing chain
Freeze Plugs
Plug Wires
Oil Pump
I have a brand new water pump $20 and shipping if you want it.
Quote:
Im not following you? I want an UN-turned crank, stock, in good shape, THUS standard sized Bearings.Originally Posted by TIMMYS89GTA
how do you know what size bearings you need if you still need a crank? ----------
Quote:
Ill take it, I Pm'd you.Originally Posted by jstoltz
I have a brand new water pump $20 and shipping if you want it. Member
Duts87ss
close
- Join DateAug 2005
- LocationOcean Springs, MS
- iTrader Positive Feedback100
- iTrader Feedback Score(10)
- Car1987 Monte Carlo SS
- EngineHSR 383 AFR180/268XFI EBL
- Transmission200-4R, Edge 2800 L/U
- Axle/Gears7.5/3.73/PowerTrax No-Slip
- Liked:0 Times in 0 Posts
I've got a Mallory 85 series distributor with Accel coil that I'll go $115 shipped on and a Summit 14x2 air cleaner with reusable filter and filter lid that I'll do $65 shipped on.
