[FL] NEED Smog delete pulley/bracket V6-see pic
Old Mar 7, 2009 | 11:23 PM
GRANDZINGA's Avatar
Car: '92 FIREBIRD
Engine: V6 - 3.1L - MPFI
Transmission: 5 speed manual
Axle/Gears: stock
I would like a better $ deal than the $ for a new gm part, if anyone can pick one up off the older '88? etc. (V6) that had no smog pump but used this idler delete pulley and bracket. Thanks.
Old Mar 8, 2009 | 10:55 AM
quick ones's Avatar
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
Re: NEED Smog delete pulley/bracket V6-see pic
If you have the smog pump you can take it apart and remove the vanes . Best part is its FREE
Old Mar 8, 2009 | 11:26 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
that not the right smog pump delte for a V6. I will look and see if I can find a pics of some ones that I had before. Dont have any right now.
Old Mar 19, 2009 | 08:28 PM
GRANDZINGA's Avatar
Car: '92 FIREBIRD
Axle/Gears: stock
Can't find ANY Fbodies let alone V6 partcars anywhere here in S.W. Florida salvage yards. Can't anyone locate one of these pulley bracket set-ups for the V6? somewhere? out there?
Old Mar 19, 2009 | 11:11 PM
kurfbird's Avatar
I will keep looking. But so far no luck
Old Mar 19, 2009 | 11:12 PM
kurfbird's Avatar
And I cant find the pics. It looks like a braket with a wheel attached
Old Mar 20, 2009 | 12:00 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
FYI the GM smog delete pully is an export only item, doubt you will find one on a car in the US unless someone else installed it. I work at a Chev dealer and I had to pull teeth to even get them to ship us the part since it was export only and I had to explain I was using the serp setup on an older car.
Old Mar 20, 2009 | 12:46 PM
GRANDZINGA's Avatar
Car: '92 FIREBIRD
Axle/Gears: stock
I thought that there were 2.8 V6 cars around '88 that came stock without the pump and with this bracket/pulley here in the U.S.??? Wouldn't this bolt right on my '92 3.1??? This is what I've heard before. Wrong? Right?
Old Mar 20, 2009 | 01:52 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Autozone carries them for an 86 Camaro with a 2.8. Wrap some string or fishing line around the pulleys and measure it. That way you can be sure you're getting the right one. You can just remove the smog pump then.
http://www.autozone.com/autozone/cat...em%40f30bc9%5D
If that link doesn't work, its P/N 4040490
Old Mar 20, 2009 | 05:00 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Where in S.W. Fl are you?
I'm in Fort Myers and might be able to help you out with looking around at least
-jason
Old Mar 20, 2009 | 08:26 PM
GRANDZINGA's Avatar
Car: '92 FIREBIRD
Axle/Gears: stock
Yep I'm just north of Lee Co. line above Ft. Myers.
Old Aug 19, 2009 | 11:58 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
still need it?
Old Aug 20, 2009 | 10:13 AM
GRANDZINGA's Avatar
Car: '92 FIREBIRD
Axle/Gears: stock
Yes I still need one.
Old Aug 20, 2009 | 01:38 PM
Axle/Gears: Stock
I have a gutted smog pump which is just a free spinning pulley off of my 89 305 if your interested.
Old Aug 24, 2009 | 08:56 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
just take the smog pump off, get a shorter belt, and re-route it. thats what i did. I'll get you the pn off of my belt next time I have the hood up. that's free (except belt purchase), saves weight and looks better.
Old Sep 2, 2009 | 12:40 PM
LT1guy's Avatar
Car: 1987 Trans Am
They aren't export only...Redraif's car had one stock, and I have seen several of them over the years. I'm going to one of our local yards this week, if I can find one what is it worth to you, shipped?
Old Sep 6, 2009 | 11:24 AM
livewire's Avatar
Car: 1983 Z/28
Maybe not, but its listed as export only in the GM parts catalog.
Old Sep 10, 2009 | 12:54 PM
LT1guy's Avatar
Car: 1987 Trans Am
Not doubting you at all on that part. I didn't even know it was still available. Correction to my previous post: Redraif's didn't have it stock, but we did add it later due to excessive belt whipping (junkyard). It was someone else I knew, who owned an 88 camaro, that had one on the car stock.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
mantaguy
Sep 2, 2015 10:42 PM
