[IA] looking for posi unit
Old Apr 22, 2009 | 11:07 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
im looking for a posi unit for my 10 bolt 26 spline..series 2 or 3 carrier doesnt matter..will probably put different gears on it anyway! let me know whats out there..thanks!
Old Apr 22, 2009 | 11:57 PM
904EDZ28's Avatar
Car: 85 IROC-Z
Axle/Gears: stock 3.23
Re: looking for posi unit
Where are you at. I am in Jax. FL. I have a limited slip diff. I pulled from a 87 IROC that had I believe a 2.73 gear. If that works let me know. I also have the axles but not the gears or housing.
Old Apr 23, 2009 | 02:05 AM
t/a350vtpi's Avatar
Car: 86t/a-ws6
Engine: vortec350tpi
Transmission: s/s-th700r4
Axle/Gears: 3.73posi
Got a 26 spline posi from my 86t/a ws6 with about 70k on it. Let you have it for $100+ship. to you. I'm in Illinois LMT. Good luck. Forgot, it's a 3 series.
Old Apr 23, 2009 | 12:23 PM
doop327's Avatar
Car: 86 iroc-z
Engine: 355 vortec heads, 750dp, xe268
Transmission: 700r4 kitted
Axle/Gears: 3.23 posi 10 bolt
i have a 26 spline posi with4.11 gears all gm stamped. it works great.im in va
Old Apr 23, 2009 | 05:47 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
ya im having problems with mine...ends up kicking out the left wheel when hammering it around a left corner so basically no slide..and absolutely no slide going around a right turn
Old Apr 23, 2009 | 09:59 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
im looking towards a eaton unit
Old Apr 24, 2009 | 05:01 PM
cbmotorsports's Avatar
Car: 1988 GTA
Engine: 5.7
I have a brand new Eaton 3 series 28 spline and a set of stock third gen 28 spline axles to match it. I am in IL. Let me know if you are interested.
92projectcamaro
Dec 8, 2015 12:25 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
tattmann
Sep 27, 2015 05:20 PM
ironbmt
Sep 27, 2015 06:00 AM
