vss
Old Jul 26, 2009 | 07:47 PM
mikedingus's Avatar
vss
Hey guys I need some information.
I recently swapped the engine and the transmission from a 89 2.8l v6 rs into a 91 Camaro rs I believe it is the original transmission for the 89 2.8 v6 however I do not know the name of the transmission.
I need the name of the transmission and a vss for the transmission, because it would be easier just to put that on the transmission instead of swapping out the cable.
Old Jul 27, 2009 | 09:28 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: vss
If you put an 89 Engine and tranny into a 91: ( both tranny's are 700R4 )
Your 91 cluster will need an electric speedo signal. If you used the 91 engine harness than pull the speedo sensor out of the original 91 tranny and stick it into the 89 set-up. You can't use the cable speedo unit unless you spend a lot of $ converting the dash cluster, or using a Cable X conversion. If you used the 89 harness than you will need to install the 91 speedo sending unit and splice 2 wires from the sending unit to the dash wiring harness get get the speedometer working.
** While swapping the speedo sending unit look at the speedo gear on the inside of the tranny. The one in the 89 tranny must be the same color and tooth count as the 91 tranny or the speedo will be "off".
the 89 tranny should use speedo gears for 3.42 gears
The 91 tranny ( if engine was 3.1 ) should have 3.42 speedo gears with a stick and 3.23 speedo gears with an auto.
You will not know the "exact" Speedo Sensor you need to buy until you verify what speedo gear is inside the 'new' tranny compared to the speedo gear inside the 'old' tranny !
Old Jul 27, 2009 | 08:14 PM
mikedingus's Avatar
Re: vss
Thank you for the information. I went to advanced and order the speedo sensor for the 91 3.1 being off isnt our biggest concerns right now; something I can change it out later when Im done with the big project. Hopefully .19 isnt going to make it to bad.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
