Cam wanted
Old Sep 18, 2009 | 07:28 PM
racprops's Avatar
Cam wanted
Well after hours of carefull research I found two possable great cams, GM Factory only to learn thay are no longer for sale...
Any one know where I can get cam number 10066049 or 14093643
The first one is from a 88/89 Camaro and the second one is called a L98 Corvette and IROCK Camaro..
Rich racprops@***.net
Old Sep 22, 2009 | 08:46 AM
cvz6977's Avatar
Car: 89 RS
Engine: 355
Transmission: T5 B&M Shift kit with short throw
Axle/Gears: 3.73 Posi
Re: Cam wanted
Not sure about those part numbers, but I do have a spare 420/420 cam with lifters, almost new. Used for original break in. I just went with a bigger lunati cam and lifter set up.
Old Sep 22, 2009 | 08:54 AM
racprops's Avatar
Re: Cam wanted
Any other info on it??
Is there a part number on it?
Make?
Rich
Old Sep 22, 2009 | 09:36 AM
cvz6977's Avatar
Car: 89 RS
Engine: 355
Re: Cam wanted
Here is a link to the spec page. http://www.compcams.com/Technical/Dy...68H-10_001.asp
I was mistaken on the numbers, went to the man cave to pull it out and it turns out it's a bit better cam than I thought. Some reason I thought it was a summit cam.
Old Sep 22, 2009 | 09:43 AM
racprops's Avatar
Re: Cam wanted
Thanks for trying...
Rich
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
nuggie
Aug 25, 2015 01:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
