[WY] Posi wanted for 10 bolt
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Hi guys. I am looking for a good posi unit for a 10 bolt rear end. I would consider buying a complete rear with 3:23 or higher gears, but most guys aren't willing to ship such a large part.
Please let me know. I hate open diff.
Thank you all.
Thank you all.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Posi wanted for 10 bolt
If the LS is for your 86, the axles are 26-spline. You might consider upgrading to an Eaton and 28-spline axles--should money not be a concern (but when isn't it?).
JamesC
JamesC
Car: 1995 Formula
Engine: LT1 350
Yes, I realize I will have to change to 28 spline. Would a 2 series be OK? I'm not up to speed on rear end stuff.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Car: 87 TA
Engine: 305 tpi
Transmission: auto
Forgot to add that to about the torsen, it requires 28 spline axles, and the 2 series carrier is for 3:23 and lower gears unless you get a gear spacer(not recomended) or get a brand new thicker gear from an aftermarket source.
Car: 1995 Formula
Engine: LT1 350
Ah, OK...I read that somewhere, but I forgot. Thank you.
!JamesC
Car: 1995 Formula
Engine: LT1 350
I found an Auburn on Ebay some time back for $150.00. I shoulda jumped on that.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Here are links to the first three I found, but I only looked at the first of seven pages.
http://cgi.ebay.com/ebaymotors/GM-7-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/AUBUR...Q5fAccessories
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
I have an eaton posi I bought a few years back for a 28 spline its a 3 series Its still in the box it was shipped to me in. IF interested let me know.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
