[IA] Need 89 TPI Interior Harness/ECU/Etc.
Old Jan 26, 2010 | 11:33 AM
ddab's Avatar
Engine: 355
We need a unmolested interior harness for our 1989 Trans Am--auto car with 350 TPI. The previous owner was trying to install an aftermarket alarm. He hacked the harness, took out the VATS and the starter relay, chopped the steering column wiring. Numerous shorts created giving a no crank/no fuel situation. We want to start over with a known good, unmolested harness...prefer all relays...will consider steering column if keys are available.
Thanks in advance.
Old Jan 26, 2010 | 07:38 PM
Guest
Guest
Posts: n/a
Re: Need 89 TPI Interior Harness/ECU/Etc.
i do not have a trans am but i do have a 87 iroc tune port the complette harness and alli do believe it will work i live in saint cloud fl. steven.tuck33@yahoo.com if you still need 225.00plus shipping only because you get everything and i have to remove it let me know
Old Jan 26, 2010 | 11:35 PM
ddab's Avatar
Engine: 355
Thanks. We are really looking for an 89 because of the cold start injectr delete. But I will keep it in mind.
Old Feb 3, 2010 | 08:11 PM
TRANSAMCRAZY's Avatar
Car: 87 T/A,92 T/A,
Engine: 406TPI,355TPI,
Transmission: 700R4 for all
Axle/Gears: 4.11,3.23,
I have an 88 Trans Am TPI car runs and drives will be junking in the next week will pull harness and ecm when i pull the 350 out
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
