full t5 swap setup
Old Mar 27, 2010 | 09:48 AM
bomberpilot07's Avatar
Car: formula
Engine: lb9 305 tpi
Transmission: wct5 swap
full t5 swap setup
ive got a 89 formula with a 305 tpi and 700r4, recently decided to go with the t5 swap. i have cash and i need a full kit.
I'm looking for a complete T5 swap
T5 trans (world class preferred)
shifter or aftermarket pro 5.0
console shift plate
flywheel
clutch
pressure plate
pedals
hydraulics
misc. fasteners
and anything else it will need.
if anyone is in or near houston i would be more than happy to come pick it up! show me what you have and ill get back to you asap.
thanks!
Old Apr 3, 2010 | 09:09 PM
Sgt. 56's Avatar
Car: 84 Z28
Engine: 454
Transmission: LT1 T56
Axle/Gears: Moser 12 Bolt Posi with 3.73 gears
Re: full t5 swap setup
I have a complete setup i pulled out of my 84 Z28. I have the bell housing, trans, shifter, torque arm, cross member and slave cylinder. If you're still interested e-mail me back. Thanks.
Old Apr 4, 2010 | 01:17 AM
Car: formula
Engine: lb9 305 tpi
got a transmission. all i need now is the following.
slave cyl resevoir and cap. pilot bushing or bearing? still not sure which one fits my car.
pro 5.0 shifter, lower rubber shift boot, and clutch fork boot.
Old Apr 8, 2010 | 11:18 AM
goose21's Avatar
Car: 85 Monte Carlo, 93 C1500, 98 Neon
Engine: 355, 4.3L, 2.0 DOHC
Transmission: T5, 4L60E, T350
Axle/Gears: 2.73, 3.42, 3.94
Get a pilot bearing. It will have little needle roller bearings inside that are nicer than the brass or bronze bushing. They are pretty much all the same for SBC engines. Just don't get one for a Ford and you're good to go.
I would buy a new clutch master, slave cylinder, and line from the dealer. Get one for a 94 Camaro. It will have a stainless hydraulic line that is a little longer than the crappy plastic one that comes on 3rd gens. You can route the line away from exhaust this way and not worry about burning it up. I think the dealer price for the whole hydraulic setup is around $130.
Good luck!
Old Apr 9, 2010 | 12:27 AM
Car: formula
Engine: lb9 305 tpi
alright.
as for the clutch master and slave... like this? http://www.nookandtranny.com/mm5/mer...ode=HYDRAULICS
will that bolt right up to the bellhousing without any trouble?
Bubbajones_ya
Jul 6, 2024 08:32 PM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
