[VA] need a new rear end
Old Apr 6, 2010 | 07:29 AM
overboost07's Avatar
Car: 1988 pontiac trans am gta
Engine: 305 tpi
Axle/Gears: factory
need a new rear end
just like the title says i need a posi rear end for my 88 gta, mine has recently been making alot of noise and only one wheel is spinning
Old Apr 8, 2010 | 02:34 AM
Engine: 305 tpi
Axle/Gears: factory
Re: need a new rear end
ttt
Old Apr 8, 2010 | 02:54 AM
chriscutlass's Avatar
Want a title? Post!
hi i have a 3.73 posi rear with disc break set up on it, im located in nj, lmk if your interested
Old Apr 8, 2010 | 02:57 AM
Engine: 305 tpi
Axle/Gears: factory
how many miles ad how much? i really just need the differential
Old Apr 8, 2010 | 03:06 AM
Want a title? Post!
the rear and the whole car for that matter has 112k,i chaged the dif. fluid like around 75k miles 80w90 castrol oil, both tires spin and im lookin to get around $250 for it, needs to be sand blasted and painted, dosent leak and has fresh gasket and oil, needs also new break rotors and pads
Old Apr 8, 2010 | 03:13 AM
Engine: 305 tpi
Axle/Gears: factory
any way you could just part with the diff?
Old Apr 8, 2010 | 03:20 AM
Want a title? Post!
i dont have the tools to take out the gears and everything, sorry
Old Apr 8, 2010 | 03:49 AM
Engine: 305 tpi
Axle/Gears: factory
well it'd take me a couple weeks to get the money for the rear end and then prolly another 2 weeks to afford shipping lol
Old Apr 8, 2010 | 04:00 AM
Want a title? Post!
where in va are you located, im near the jersey shore like 15 min away, i mean ill hold it for you till you got the $ but i gota be sure that you want it tho.... heres my cell to make arangements and everything 732 908 0099-chris
Old Apr 8, 2010 | 04:06 AM
Engine: 305 tpi
Axle/Gears: factory
im in sw va, bristol to be exact, you dont have to hold it for me, if you find someone else that wants it then go ahead, ill will get in contact with you when i do get a little bit saved up. thanks chris
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
