AFR 190 SBC 305ci heads
I'm looking for a set of the old AFR 190 aluminum heads that were for the 305ci SBC engine. AFR Kit 1019, AFR Item No. 1147. I believe they were discontinued around 2002. They will have 1.94/1.56 (1.550) valves with 56cc combustion chambers. Also 72 degree angle intake bolts and hopefully drilled for center bolt valve covers.
If you have a set of these you are willing to part with, bare or complete, please drop me a line with pictures and asking price.
Thanks!
Thanks!
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: AFR 190 SBC 305ci heads
I have set of those but mine are modified to accomodate a 2.02" intake valve and won't work on a 305 now. Good luck on your search. Those are great heads.
Transmission: 200R4
More information that might help you locate a set.
https://www.thirdgen.org/forums/afte...-afr-305s.html
Nothing like a good divorce to set a guy back on his plans 6 years lol!
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Good luck man. I just did a search on google and all it brought me back to was this thread.
Transmission: 200R4
I first learned about them reading this article.
http://www.purplesagetradingpost.com...%20engine.html
Transmission: 200R4
I can give you the name and number of the guy who owns mine. Problem is they did get 2.02 valves. It would take a fair amount of work to get seats installed with 1.94" valves. Good news is the guy is the owner of a top notch head porting shop and can do the work. The heads also got a full port job by AFR. I did frag two pistons so two of the chambers have specs but they aren't bad. Let me know. It may be worth your time and money as these heads are very scarce.
Sounds like for the work they would need I would be equally as well off getting a set of bare cast heads and having them machined, which I already have a quote for.
Thanks tho!
Thanks tho!
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I've been looking for a set too...
I'm starting to look at the TrickFlow 175's for the 305...
I saw a article where they added over 100hp on an engine per the dyno sheet...
Summit as them bare for $450 each, a bit more with hardware...
And they have accessory holes, always a plus
Rafael
Rafael
Ah yes, these:
http://www.summitracing.com/parts/tfs-30310007
Those are in fact my fall back as they are also C.A.R.B. approved.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Feb 28, 2016 03:33 PM
