Need a MAF sensor
Old May 8, 2010 | 09:58 PM
dpmalibu's Avatar
Need a MAF sensor
Need one ASAP for an 86 Z-28 w/ 350 . Must be in good working condition. No cracks, chips anything like that. The one on the car I picked up must have a crack in it b/c it has electrical tape wrapped all around it. Post up pics if you can w/ a price shipped to Hatboro,Pa 19040
Thanks!!!!
Old May 8, 2010 | 10:10 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Need a MAF sensor
Thanks!!!!
Personally, at the rate that these fail, I would rather buy a reman with a warranty...
Old May 8, 2010 | 10:33 PM
dpmalibu's Avatar
How much do they go for and where can I get one from?
Old May 8, 2010 | 10:38 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
you sure it's an 86 and or a 350... the only listing I get is for a 305....
Old May 8, 2010 | 10:39 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
well for a 305, autozone shows them for 125.00 with a 1 yr warranty... plus a core of 80 dollars...
Old May 8, 2010 | 11:02 PM
dpmalibu's Avatar
its an 86 with an 87 vette 350 in it and a bunch of other stuff done to it.
Old May 8, 2010 | 11:52 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
well now... if you are using the Vette's ECM, then you will have to look it up under the Corvette specs...
edit:... looks like it's the same P/N...
Old May 9, 2010 | 08:07 AM
dpmalibu's Avatar
Okay thanks. I basically just wanted to try to get it to run a little better before I pull the motor. I am saving the motor for my truck and parting out the rest of the car.
Old May 9, 2010 | 08:14 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
my personal opinion, if the engine is mostly stock aside from a few bolt-ons, look into converting to speed density... you have to maintain the MAF pretty clean in order for it to work properly and not crap out.. this is somewhat from experience on a 2.8 Camaro...
Old May 9, 2010 | 08:41 AM
dpmalibu's Avatar
It's not stock. It has a Crower roller cam, Trick Flow heads, roller tip rockers, BBK Throttle body, Ported intake, Custom chip, BBK adj. fuelpressure regulator ,headers, 11:1 pistons supposedly. So it is far from stock. i wasn't planning on keeping the TPI anyway but I wanted to get it running better before I pull the motor. I don't want to spend money getting it tuned since I will be changing over to carb eventually anyway.
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
