[PA] Condensor needed for 86 TA
Car: 1986 Trans-Am
Engine: 305 4BBL
Transmission: THM 700 R4
Axle/Gears: 2.73 Stock
Part needed is the condensor for an '86 Trans Am.
Car: 1990 Camaro RS
Engine: soon to be 383 stroker
Transmission: t5
Axle/Gears: soon to be 3.73
Re: Needed: OE ECM controlled distributor for 305, AC and emissions parts
i have it all if you are willing to pay for shipping.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I have a distributor, OEM, a touch of surface rust but solid with no play in shaft or wear on gear, set of the Air tubes (parts that screw into exhaust) very clean, and air lines from dryer to compressor and condenser in perfect shape for a 305 TBI, not sure if they're the same. Reasonable prices and can send pics later if give me an email address Let me know, I'll check back this evening. Henry
The distributor is the smaller, remote coil model
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have all the compressor mounting brackets for this engine and year, carb style '86
also earlier 1980s years
good luck
good luck
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
I have an 88 Distributor, w/ Accel Rotor and Cap, plus a new gasket. The new Cap and Rotor have about 200 km's on them.
I can ship it off in an MSD Distributor Box, so it's good to ship. PM me if youre interested. I also have all of the required smog equipment that you need except the tube that wraps around the engine, and the one that goes down to the cat, BUT I have everything else, and it's all in GREAT shape.
So just drop me a PM and we'll deal.
Here's a pic of the dist like you asked, turns out I had one on my comp already.
And the pics of the smog equipment, all clean and ready to ship, and all in working condition.
I have a smog pump with brackets and a/c compressor with brackets off of an 86 305 tpi engine that was in an 86 Trans Am. I can get you pics if you want to see them just give me your email and ill send the pics. Make me an offer.
Car: 87 Z-28
Transmission: Automatic 200 Metric Turbo
Axle/Gears: Strange Axles & 5.14 Gears
Re: Condensor and AC lines needed for 86 TA
I have a A.C. condenser for $20. plus ship.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I still have great condition AC lines from condenser to compressor and to receiver. Send email address if you want pics. Foam insulation in perfect shape . $25
Zachattack0925
Aug 12, 2015 09:52 PM
