[NJ] 882 Cylinder Head Needed, Single or Pair, Doesn't Matter....
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Hey guys, I need a 333882 cylinder head off of either a 350 or 400 from the 70's, also stamped 1A on the combustion chamber side of the head. Should be 1.94/1.50 76cc. If you have the one, or if you need to let go of a pair, doesn't really matter, I just don't have the time to hit up the bone-yard, so lemme know what you got....
Thanks,
-Rob
Thanks,
-Rob
Want a title? Post!
Car: 87 IROC under construction
Engine: 355 carburated roller eng.
Transmission: have 700r4 WANT 350 turbo 4000 conv
Axle/Gears: weak stock rear
Re: 882 Cylinder Head Needed, Single or Pair, Doesn't Matter....
I have a couple sets I will check to see if any of them are 1.94/1.50.
They are all off 350s that I have. I will check tomorrow for you , if I have it I will part the set if you want.
I see you are running 11.50s,what rear are you running ? How hard are you leaving?
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I think I still have a pair that would need gone through. They were from a 400.
Thanks guys, let me know what you have whenever you get the chance. The GTA is running a 10-bolt w/3.42 gears out back. Reaction time was poor because I was trying to see how much boost I can build off the line using the foot brake method, but the rear discs weren't holding well at all. Still managed a respectable 1.71 sixty foot. Boost was set at 12-psi....
Want a title? Post!
sorry I have two sets of 7A which have the 1.94 valve and a single 26A which has the smaller valve.If the 7A will work let me know you can have it as long as you pay to ship it or pick it up.
How much converter I hear these rears( stock 7.5 10 bolt) break easy ?
Engine: that I like
I checked and still have them, they have the 1A marking on the bottom. The 400 they came off of ran OK with fresh plugs in it, I noticed a broken valve spring when I took it apart. It was tired in general though. Anyway, point is there were no overheating issues.
If you're interested, I'll check on shipping.
