want t5 tranny
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Re: want t5 tranny
I have a T5 set up
it was in a 91 camaro Rs 112k original miles less then 900 on rebuild
All New seals/syncros/solid input shafts ect (this alone was $950)
Shifter (Stock)
Stock Clutch/pressure plate with some life left
Flywheel for pre 86 motor(2 peice rear main seal)
Id take $850+Shipping
I am in Chillicothe Ohio 45601
I have all the stuff for swap except slave cylinder/fluid resivor/clutch fork(i might have this)
614 364 9995
Shifter (Stock)
614 364 9995
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Re: want t5 tranny
What do you have right now for your car? I have a T-5WC setup that I swapped in but now I want the 700-R4 back lol. The trans does need a rebuild but the slave cylinder, clutch master cylinder, and clutch setup are brand new. Everything would be up for trade for a complete 700-R4 setup.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
