305 carb wanted
Old Nov 17, 2010 | 04:28 AM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
305 carb wanted
Anyone have a complete carbureted V8 engine and wiring for a 1987 car?
Old Nov 17, 2010 | 07:34 PM
chronos51's Avatar
Re: 305 carb wanted
yep. well it needs the driver valve cover and oil filter attachment (the threaded part on the motor) ran before I took off the tranny. out of 87 gta. I live in twin falls Id. I have no idea what shipping would be. 250 and if you come get it you can have it and anything off the car you want or need.
Old Nov 17, 2010 | 07:50 PM
Sandslot's Avatar
Engine: LB9
Re: 305 carb wanted
Thanks for the offer, but it's a little far from Troy Michigan. Appreciate the response though!
Old Nov 17, 2010 | 08:07 PM
chronos51's Avatar
Re: 305 carb wanted
hey not a problem. hope you find what your looking fior. I have lots of parts off this gta interior plastic (red) fairly new carpet (red) t-top glass. rear bumper cover, suspention(sp).
Old Nov 27, 2010 | 04:33 PM
Teddybear's Avatar
Car: '92 Firebird
Engine: V6
Transmission: AT
Re: 305 carb wanted
Is the carb still available? Its a computer-controlled Rochester, right? I have an 87 305 currently running a carb from a Bonneville and I'm looking to go back to the proper fitting. (916) 868-7310
Old Nov 27, 2010 | 05:38 PM
chronos51's Avatar
Re: 305 carb wanted
yes the carb on the motor offered above is still available. it has 3 computer components on it. otherwise it looks like a rochester quadrajet 4bbl. ive got pics is the number you left a cell and do you accept txt msg?
marcus
Old Dec 3, 2010 | 09:15 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: 305 carb wanted
I have an entire 87 firebird running driving with a 305 carb 700r4 if youre interested. I'm just around the pond though.
Old Dec 3, 2010 | 09:17 PM
Sandslot's Avatar
Engine: LB9
Re: 305 carb wanted
Thanks for the note....sounds like its still in a car & I am ready now. thank you anyway!
Old Dec 8, 2010 | 11:53 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 305 carb wanted
I have a 305 with carb, complete (heads, valce covers, oil pan etc) minus wiring harness that came out of my 84 T/A when I did a 350 swap here in Salt Lake City. The motor was running when pulled but has been sitting for two years so probably needs to be gone through.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
