[OK] IAC adapter for TPI throttle body
Old Feb 10, 2011 | 03:24 PM
MPIpowered4x4's Avatar
I need the IAC adapter and screws for a TPI throttle body, with IAC valve.
Old Feb 10, 2011 | 05:19 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: IAC adapter for TPI throttle body
You mean the housing that the valve screws into? And for what size engine?
Old Feb 10, 2011 | 08:35 PM
Ya...its for a Lingenfelter 58 mm throttle body, the stock one should bolt on right?
Old Feb 10, 2011 | 08:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Not too sure about that. Well, for 5.7 TPI I guess. You have any instruction sheet that says stock one should fit?
Old Feb 11, 2011 | 06:21 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I found two slightly different ones. One from a 91 Z28 5.0TPI engine, the other from a 94 Z28 5.7 TPI. They look like the mating faces are identical, but the hose fittings are a little different and the earlier one has the screw in IAC, the other has the later bolt on one with the right angle connector. Both have the IAC and connectors if needed. Get me your email if you would like pics or
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
