10 bolt brake mounting plate
Old May 22, 2011 | 03:03 AM
gpingu87's Avatar
Car: 86 trans am ws6
Engine: 02 ls1 swap in progress
Transmission: 4L60-E swapping with engine
I have a 86 firebird that came with a 9 bolt posi. was worn out and found a cheap 10 bolt from a 85 that had drums on it. swapped out the 2 and afterwards found that the mounting plates for the calipers are different. so looking for a set of those mounting plates for a 10 bolt. thanks for any replies.
Old May 28, 2011 | 09:59 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: 10 bolt brake mounting plate
I've got a complete 10 bolt out of my 84 that I am selliing. Good calipers, rotors, 3.73 gear, LCARB's, and long ARP wheel studs. It does need sides, and spiders. $150.00 plus the ride.
Old May 29, 2011 | 07:06 PM
gpingu87's Avatar
would be interested in it. where about in IL are you and how would we work out the drive?
Old Jun 1, 2011 | 07:17 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
I am located near the Peoria area, where in michigan are you located. I would be willing to do some driving if we can work out a deal. Feel free to pm me if you want.
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
