[CA] Wtb 2032 cam
Old Jun 8, 2011 | 07:04 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Wtb 2032 cam
Im wanting to buy a crane 2032 cam used since i dont feel like spending over $200 for a cam right now.
Old Jul 21, 2011 | 02:23 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
TTT
Old Jul 22, 2011 | 04:30 PM
GOTCHEVY's Avatar
Car: 97 Z28
Engine: 396 LT1 518whp All Motor
Transmission: 6spd
Axle/Gears: 4.10 LSD
Re: Wtb 2032 cam
How about a cc304?
I have one I wanna get rid of
Old Jul 22, 2011 | 10:46 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
Is it roller and u got the specs?
Old Jul 22, 2011 | 11:12 PM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: Wtb 2032 cam
COMP cam hydraulic roller
Grind number- CS 266H-R14
210/220 @.050
266int/276exh duration
.500int/.510exh lift
114LSA
Old Jul 23, 2011 | 01:47 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
How much you want for it and were you located?
Old Jul 23, 2011 | 07:17 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Wtb 2032 cam
you do realize getting that cam requires you to do headwork... meaning at least springs retainers and screw in studs to handle the lift of that cam..duration is good dont NEED any tuning for that considering that the 2032 cam is 214/220 duration.... but getting that other cam means alot more money in the heads.....
Old Jul 23, 2011 | 07:46 AM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: Wtb 2032 cam
$200 shipped
Coachella valley 760 area
Old Jul 23, 2011 | 05:44 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
Damn i didn't know i would need the screw in studs... ima have to pass on it then
Old Jul 23, 2011 | 06:19 PM
88fastgta's Avatar
Re: Wtb 2032 cam
yeah.. not tryna ruin your sale GOTCHEVY but sickrs you put that cam in with your stock heads then your going to ruin your engine.... you NEED head work to run that cam.....
Old Jul 23, 2011 | 10:43 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
I thought it was just the springs needed... since the screw in studs i canot afford that machine work right now and the springs ima change myself.
Old Jul 24, 2011 | 09:42 AM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: Wtb 2032 cam
I'd like BOTH of you to read this article...
http://www.carcraft.com/techarticles...ade/index.html
Not sure what heads your running but just to give you an idea that NO you dont always NEED headwork...
Find the right springs that will work for your heads bro and you'll be fine...
Old Jul 25, 2011 | 05:59 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
Im running stock 083 heads that link you posted has me thinking if it will work on mine since that one says for vortecs.
Old Jul 25, 2011 | 07:34 PM
88fastgta's Avatar
Re: Wtb 2032 cam
stock 083 heads take a max lift of .470.... you put a .500 lift cam in there with stock springs and stock press in studs, your asking for a world of trouble..... its not recommended to use press in studs with cams in the .500 lift range.. because when you rev that engine up or get into the rpm band you have a high risk of pulling the studs right out of the head... sickrs for any decent cam swap you want better springs retainers and screw in studs.... you dont NEED screw in studs but why skimp out on something thats relatively cheap now than coming to find out the you pulled one of your studs out because you were trying to save a few bucks and now have to dish out well over a grand to fix your head or worse you engine if its bad enough... there are ways of doing things... you dont put in a cam like that and not switch over to screw in studs and proper springs.... you can do what you want but cheaping out and crossing your fingers hoping it will work is not a good idea... personally if your not going to get new springs retainers and screw in studs i would pass....
Old Jul 25, 2011 | 07:38 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
Oh ok well im just not wanting to spend over $400 on modding my heads since with that money i could put towards getting some used heads for $600 thats why i was thinking of going with the 2032 cam
Old Jul 25, 2011 | 08:08 PM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: Wtb 2032 cam
Well i ran that cam on bone stock Vortecs with pressed in studs...motor lived at 6000 rpms...no problems ever
Dude i got what you need right here.
https://www.thirdgen.org/forums/engi...-350-comp.html
Im selling my setup cuz im going much bigger...maybe AFRs with 230 cam
But im sure 88 will find some reason to talk you out of it
Old Jul 27, 2011 | 11:46 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
You got a text man wondering if u could make men deal
Old Jul 28, 2011 | 12:11 AM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: Wtb 2032 cam
http://www.summitracing.com/parts/NAL-12558060/
Old Dec 29, 2011 | 06:31 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Wtb 2032 cam
Old bump
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
