3.73 ring and pinion
Old Sep 9, 2011 | 07:06 PM
wakeboardr42393's Avatar
Car: 1987 BMW 325is
Engine: M20B25
Transmission: Getrag 260
Axle/Gears: 3.73 LSD
Hello, i am looking to buy a ring & pinion set for a GM 10 bolt rear end. preferrably for a series 3 carrier. let me know what you have! thanks!
P.S.,,, if you have a complete carrier assembly with 3.73 gear i will gladley accept this.
Old Sep 9, 2011 | 07:28 PM
T/A IN PA's Avatar
Car: Trans am
Re: 3.73 ring and pinion
I have GM 7.5 10 bolt 3.73 Richmond Gears and install kit. 49-00461 , 83-10441 New in box. Boxes a little beat up from sitting in garage. I can send pics, need email address.
$250 shipped.
Old Sep 10, 2011 | 09:55 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
I've got the complete disk rear end with 3.73's, lcarb's and long studs, does need sides and spiders though. Let me know
Old Sep 10, 2011 | 09:56 AM
Car: 1987 BMW 325is
Engine: M20B25
$250 shipped.
allright cool! my email is wakeboardr42393@hotmail.com. if you can send a pic or 2 itd be cool. and just curious, would you take 200?
Old Sep 10, 2011 | 09:59 AM
Car: 1987 BMW 325is
Engine: M20B25
wasnt really looking for a full rear, but hey mabey. how much?
Old Sep 10, 2011 | 10:02 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
250.00 plus the ride.
Old Sep 10, 2011 | 10:09 AM
Car: 1987 BMW 325is
Engine: M20B25
dang. that sounds like a good price. and dont mean to sound stupid, ive never done any rear end work before, but what are sides and spiders? do you mean the spider gears in the differential? and also what is lcarb? and if i have regular GTA wheels will the long studs be ok? and is it a limited slip unit?
dont mean to bother you by all the questions. thanks!
Old Sep 10, 2011 | 10:15 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
They will work with long studs, but you would have to use open end lug nuts. lcarb's= lower control arm relocation brackets. This was an open rear end, would need new side and spider gears installed to make it work properly. It had a mini-spool installed, and was removed with plans to install side and spiders, but have never got around to installing.
Old Sep 10, 2011 | 10:23 AM
Car: 1987 BMW 325is
Engine: M20B25
so if i have a series 3 carrier in working order i can just bolt on the gear to that and install to have a working rear? or no? and with the relocation brackets would i be able to use the rear with my stock setup or not?
Old Sep 10, 2011 | 10:39 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Yes, take out the current carrier, and install your carrier. Done deal, not sure on the year brakes for changing from 26 to 28 spine axles, though, at most you would change out axles as well. Yes, you can use the lcarb's in a stock setup.
Old Sep 11, 2011 | 03:13 PM
T/A IN PA's Avatar
Car: Trans am
Pics sent.
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
gord327
Sep 29, 2015 10:18 PM
JSDaddy189
Sep 26, 2015 03:50 PM
