ISO: Poly motor mounts
Old Oct 30, 2011 | 12:53 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
looking for a pair of complete poly motor mounts; not the mount inserts.
Old Oct 31, 2011 | 11:06 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: ISO: Poly motor mounts
I wasn't aware that you could by a complete poly mount. I've only seen the inserts.
Old Oct 31, 2011 | 11:18 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Yeah your right, but i dont understand how i would use the inserts.
Old Oct 31, 2011 | 07:38 PM
wesilva's Avatar
Transmission: 200R4
Do you have the stock ones? If so, here is the technique I used. First I chucked up a mount in a vice. Then I took a drill and made several small holes in a pattern to where I could remove the rubber leaving just the shell. I ground down the tack welds to the shell to where I could install the inserts. Then I rewelded the shell. If anyone knows a simpler way, please share.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
