wtb alluminum disc ebrake cable
Subscribe
Nov 3, 2011 | 03:22 PM
I changed rearends from drum to disc and need a set of ebrake cables
Reply 0
Nov 3, 2011 | 03:29 PM
Re: wtb alluminum disc ebrake cable
you might want to specify what calipers you are using ?
Reply 0
Nov 3, 2011 | 03:40 PM
Its a 327 geared rearend out of I believe an '89 what do I look
Reply 0
For on the calipers?
Reply 0
Nov 3, 2011 | 03:44 PM
are they pbr aluminum
Reply 0
Nov 3, 2011 | 03:50 PM
I believe I was told it was a special rearend how do I check/ what is phrase other than cheap beer?
Reply 0
Nov 3, 2011 | 03:51 PM
Pbr stupid auto correct
Reply 0
Nov 3, 2011 | 03:56 PM
post a pic, pbr's are the 89- up aluminum calipers
https://www.thirdgen.org/forums/engi...omponents.html
Reply 0
Nov 3, 2011 | 04:09 PM
Quote: Its a 327 geared rearend out of I believe an '89 what do I look
3.27 is 9-bolt gearing. If it's truly an 89 with disc brakes, it'll have PBR's. The cables can be purchased from the following site:
http://www.flynbye.com/catalog/i199.html
JamesC
Reply 0
Nov 3, 2011 | 05:05 PM
Yeah they are pbr its an 89 borgwarner g92 aluminium disc rear I would like used cables if they are out there ..
Reply 0
Nov 3, 2011 | 05:09 PM
I have a set of used ones and backing plates, the dust shields are kinda spent
Reply 0
Nov 3, 2011 | 05:12 PM
I believe all I need is the cables how much would they be shipped to 95356
Reply 0
Nov 3, 2011 | 05:24 PM
http://i43.photobucket.com/albums/e3...s/IMG_0260.jpg
here is a picture , the one the outer coating is rubbed through but the cable seems to move.
Reply 0
Nov 3, 2011 | 05:26 PM
Price?
Reply 0
Nov 3, 2011 | 05:27 PM
pm sent
Reply 0
Nov 3, 2011 | 05:54 PM
Take note that there were two designs for PBR's. The 1st design cable, used with a tunnel-mounted adjuster, is 1434 mm. The second design is 1460 mm. This longer cable was designed for cars with no adjustment provision, the 90+ IIRC. That said, best to check what's in the car.
JamesC
Reply 0
Nov 3, 2011 | 05:57 PM
good call !!!
Reply 0
Nov 3, 2011 | 06:05 PM
mine measure 56 3/4 so I assume they are considered 1434mm
Reply 0
Subscribe
