Looking for a MAF
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
Looking for a MAF
if you have a maf sensor laying around that's good I could use one..
Reply with price and a message...
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Looking for a MAF
I have one, I'll need to test to make sure it is good.
$50 shipped.
$50 shipped.
Alright please do..I think it is my maf sensor goin bad.
QUOTE=Dyno Don;5108487]I have one, I'll need to test to make sure it is good.
$50 shipped.[/QUOTE]
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I bought a Used MAF. 1 month later it died. Spending the $150 at Autozone on a brand new warrantied MAF was well worth the $. And it is a newer, circuit board design not the OEM big cooling fins & element wire, so it can flow a bit more cfm & is most likely more accurate.
I just need a maf to see if its my problem with my car,I don't have a prob wit buying one from the part store.I just don't know what's wrong wit my car and already bought alot of other stuff that I could have used the money for something else on the car,now I have extra parts that are still new.I don't wanna spend 150 for a new one and then mine is still good then I could hve used that 150 on something else for the car...
Car: GTA
I understand that as I was trying the exact same thing & couldn't find one to borrow.
Maybe you can find someone local or in DFW to borrow one to test with? I'm close to Austin, so I'm too far away.
What running problems are you having? Any Trouble Codes at all? Mine would bounce between MAF, something else or nothing wrong, yet it always was running bad, mainly at start up until the engine warmed up. The bad MAF was causing fuel mixture issues which were mainly noticeable at start up.
Car: GTA
Wish I could use someone's to see but haven't seen any camaros around my town or other towns..theirs a Iroc ablock from me but never see them home when I am..no codes but ses light is on..seems like when the car heats up it runs bad.my ses light stays on but alil after driving it goes off and runs super bad really low idle..I can unplug the maf and ses light goes off..
I don't have one but if you would have just read my other treads seeing my problem instead of tryin to make it seem like I'm tryna be a cheap a**...
Car: GTA
Hope you figure it out. I tried to help, you copped an attitude. I had some more help to pass along, but now your attitude is getting even worse. Good luck.
You not cheap & nowhere did I say or imply you were. Your doing teh exact same thing as I was. Trying to fix THE problem, not just randomingly throwing $ at parts & hoping for a fix. And NOWHERE did you say you were just looking to borrow one to test with. I don't need to look at your other Posts & try to figure things out. You want help? Put it all in here in ONE post. Not multiple threads.
Lol now you just being funny...but ok have a nice day...
QUOTE=BlackenedBird;5109629]Hope you figure it out. I tried to help, you copped an attitude. I had some more help to pass along, but now your attitude is getting even worse. Good luck.[/QUOTE]
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
wow lopezstud87 chill man... ppl here are just trying to help you...till you **** them off.
If you want help, it would be wise to clearly state:
What your question is.
What you think is wrong
What you have tried to do to fix it
What parts you have thrown at it already.
If you are stock or not.
Also have you tried to use the search feature?
People are willing to help till you catch an attitude.
Really????...not even gonna comment on that since I have treads started on my problem..
Example of someone butting in on someone's post.
QUOTE=toxik IROC;5110015]wow lopezstud87 chill man... ppl here are just trying to help you...till you **** them off.
People are willing to help till you catch an attitude.[/QUOTE]
QUOTE=toxik IROC;5110015]wow lopezstud87 chill man... ppl here are just trying to help you...till you **** them off. If you want help, it would be wise to clearly state:
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
