WTB Intake Manifold
Old Dec 2, 2011 | 07:16 PM
tylerf's Avatar
WTB Intake Manifold
Have a 88 firebird gta auto tpi 305 LB9, need the lower intake manifold if anyone has one plz pm me Thank You
Old Dec 2, 2011 | 07:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: WTB Intake Manifold
https://www.thirdgen.org/forums/engi...tpi-setup.html
User John from RI has a 87 manifold 87-88 intakes are the same the 89 will not ahave a provision for the cold start injector timer switch.
Old Dec 2, 2011 | 09:18 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I've got a 1985 model that I'll sell cheap.
Old Dec 2, 2011 | 10:08 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Hi Tyler......
I'll pull out the intake and get some pics ASAP. What is your ZIP code ??
Old Dec 3, 2011 | 12:03 AM
tylerf's Avatar
97008 thanks john
Old Dec 3, 2011 | 12:04 AM
tylerf's Avatar
well the 85 work?
Old Dec 3, 2011 | 12:36 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I have one off of an 86 TPI. message me if interested.
Old Dec 3, 2011 | 10:57 AM
wesilva's Avatar
Transmission: 200R4
Originally Posted by tylerf
well the 85 work?
Are you running stock heads? The 1985-86 intake manifolds will fit the older small block heads without modification. In 1987 and up, the heads were designed with vertical bolt taps for the two center bolts on both sides of the intake manifold. With a little drilling the newer manifolds will fit the older style heads. The intake manifolds are therefore interchangeable for all SBC engines if you slot the two inner intake bolt holes on post 1987 heads. Confusing enough??? LOL
Old Dec 3, 2011 | 11:00 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have an '88.
Old Dec 3, 2011 | 04:10 PM
John in RI's Avatar
Here's a pic:
The intake was blasted and re-painted "Cast Aluminum" so it's a bolt-on out of the package piece. All holes were OK but they should be blow out with compressed air before installing. This is a Centerbolt, MAF, Cold Start intake manifold. The 2 bolts for the EGR, 1 bolt for the breater tube & the 2 sensors in the front of the intake were already removed. ( Coolant fitting still installed ) $90 + shipping.
Oregon is a long way from RI :
USPS Parcel Post ( insured ) = $26
USPS Priority Mail ( insured ) =$47
Send me a PM for additional details if your still interested.
Old Dec 3, 2011 | 08:01 PM
tylerf's Avatar
with has much problems i have had with the car, i really dont want to do any more drilling if not necessary, i would perfer to have the same intake with the same bolt pattern, no more drilling
Old Dec 5, 2011 | 08:01 PM
myzblubyu's Avatar
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
I have two of them... They are in great shape....
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
