[WA] Need TPI injectors and 305 prom
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
finally at the end of my list for things i need for my swap, i need a set of 350 tpi injectors that are in good shape, i dont need another set lying around that is botched, also need a 90-92 tpi prom, 305 will work, 350 is retardedly expensive now oh and im also going to need a throttle cable for a tpi (90-92) if anyone has one laying around
let me know what youve got
TIA
TIA
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Need TPI injectors and 305 prom
Look in our vendor section. Choose SouthBay. They sell 19 lb Bosch III'S for a 305 and 21 lb Bosch III'S for 350's for around $160.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Hypertech Thermomaster for 91 305 TPI; $100 Shipped. I know it worked when I bought it about 3 years ago, It's been in a box since then.
LMK if your interested.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
The hyperrech chip would be a waste for me, I'm doing my own tune, actually its based off the hypertech profile with a few tweaks I just need a factory prom that I can use as a backup for limp mode
Ill just buy the cable new since they're cheap enough and I totally blanked on southbay, I was hoping someone had a good set of lt1 injectors that could be put to use
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I have these:
82-02 V8 Ford Racing SVO Fuel Injectors (19lbs/hr)
bought new from WS6project 2 years ago, have roughly 800 miles on them
let me know
let me know
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Hey Blue....did you ever find your injectors?
Did you ever sell the T56 I sold you?
Engine: 6.0 LQ4 LSX
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Ah no lol still hunting for a set, the t56 was sold to a guy up here to pay for my engine work lol I had to drop 900 for my block to be bored out and assembled with new rods and pistons because summit kits aren't exactly worth their money, the pistons weren't close to the same weight so a ship up here sold me new gear and assembled it, I'm getting ready to yank my t5 and rebuild it, and I've been working on a white v6 I bought for my wife so I'm just waiting for the parts to pop up at a good time lol I need 22-24 lb/hour ones between the cam and the bore I don't wanna risk underfueling it
Transmission: 200R4
I got a set of Accel 24 pounders that were just serviced. I can sell them to you for $75 plus shipping.
The T56 you traded me is in my late model F150 behind a built 5.3. I've got a few tasks before it's running but it looks like it was made to be there. I'll send you the build link from LS1tech when it's running.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I will totally take you up on those injectors if you wanna hold them for me, I'm switching jobs in the next week so I don't wanna spend $ in case there's a lapse in pay periods, I'm glad that t56 worked for you I wish I could say the same for myself lol
Transmission: 200R4
I'm not peddling the injectors anywhere so hit me up when your job situation gets stable.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Well I landed another DOD job so it shouldn't lapse.... but its still the government lol
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
I have a brand new in the box AcDelco 91 305 TPI Auto Eprom 16163062. $115 shipped.
I also have a set of LT1 injectors if interested. $75 shipped
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.amazon.com/ACDelco-161630.../dp/B000IZ3KXG
The axxb is a one time only burn eprom from delphi electronics singapore.
I have some 5.7 memcal's or can tell inform you how to wire up a tbi truck 5.7L external esc to b8 of a 1227730.
Sanjay
Aug 12, 2015 03:41 PM
