T5 V8 swap kit
Old Mar 5, 2012 | 03:59 AM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
T5 V8 swap kit
I want to buy T5 V8 swap kit
My location Ukraine Kiev.
  • Meest-America
  • 641 Dowd Avenue, Elizabeth, NJ 07201
Old Mar 11, 2012 | 09:13 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: T5 V8 swap kit
Have a WC T5 w/ 0 miles since rebuild.
Asking $600 + shipping.
PM if interested.
Old Apr 7, 2012 | 05:54 AM
Car: Camaro 1988
Re: T5 V8 swap kit
Up
Old May 25, 2012 | 04:02 PM
crowbarmaster's Avatar
Car: 1982 Camaro Berlinetta
Engine: 327 with holley 4bbl
Transmission: T-5 WC
Axle/Gears: 3.42 non-posi
Re: T5 V8 swap kit
I have everything needed to swap a car (my car was auto once) to a WC 5 speed. asking 400 or bo + shipping. is that NJ address where this would be going?
Old May 27, 2012 | 12:49 AM
rigsboo's Avatar
Re: T5 V8 swap kit
24354 marion va find out about shipping im kind of interested
Old May 27, 2012 | 12:51 AM
rigsboo's Avatar
Re: T5 V8 swap kit
bellhousing and clutch and pedals? mine is automatic what else would i need?
Old May 28, 2012 | 04:54 AM
Re: T5 V8 swap kit
yep, I can send everything i needed to do exactly the task you will take on.
First, I need to know what trans and tailshaft length you have (will determine whether or not you will need a driveshaft.)
if you have a 305 in your car, my flywheel will NOT work, since my flywheel is for a two-piece rear main seal. you will need to order one or find one from the forum.
the rest should line up to any camaro, and if you have a 9in tail (found on most auto 4 speeds but some TH350 trans are shorter at 6in.) your torque arm and driveshaft will match. thats all i can think of to question at the moment. It went fairly well and we were done with only about 7 hours of work.
toronto formula
Nov 10, 2015 06:17 AM
Mickeyruder
Sep 2, 2015 02:45 PM
fasteddi
Sep 2, 2015 10:29 AM
lt1z350
Aug 28, 2015 05:57 AM
