[AR] 1989 IROC TPI Wire Harness Needed
Car: 1989 IROC
Engine: 5.7 TPI
Transmission: 700R4 w/shift kit
I need a wire harness for a 1989 IROC, doesn't have to be in perfect shape but it does need to be all together, I can repair some stuff. I also need the under the dash wire harness too.
I cannot spend more than $100.00 shipped to 71635
I cannot spend more than $100.00 shipped to 71635 Thanks
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: [AR] 1989 IROC TPI Wire Harness Needed
You didn't specify what type of engine is in your car.
I've got both an Engine harness and a Dash Harness from an 87 IROC 305 TPI. Might be a little different than your 89 harnesses, but obviously when used together they are perfectly compatable. Also have a TBI engine harness from an 88.
Each harness is priced over $100 + shipping.
mustangman65_79
Aug 11, 2015 03:17 PM
