Rear Axle U-bolts
Subscribe
May 21, 2012 | 08:35 PM
I need a pair of the u-bolts that hold the rear sway bar to the rear axle housing. The nuts as well. I have the sway bar parts from one side to the other, but I need the u-bolts to attach the bar to the rear axle. I've been trying to get these for months now and haven't gotten them yet...
Reply 0
May 21, 2012 | 08:44 PM
Re: Rear Axle U-bolts
Should be able to find some of those tomorrow. Will LYK if I do, Henry
Reply 0
May 22, 2012 | 04:49 PM
Found them. Do you need just the bolts and nuts, or the brackets they attach to as well? PM or email me your email address for pics and other info, Henry
Reply 0
May 22, 2012 | 05:25 PM
I need the bolts, nuts, and the lower part of the bolt that flattens out the bottom of the axle tube (where the upper portion of the sway bar bushing sits), basically what is almost an exhaust clamp...
Reply 0
May 22, 2012 | 05:31 PM
Yeah, I got all that. Everything that attaches it except the sway bar bushing.You want pics?
Reply 0
May 22, 2012 | 06:05 PM
Pics aren't needed... But a shipping quote to 14482 is...
Reply 0
May 22, 2012 | 06:19 PM
So you don't need the omega shaped piece that goes around the sway bar bushing? Just the two u-bolts with nuts and the parts that go between the axle and the top of the bushing?
Reply 0
May 22, 2012 | 06:52 PM
Quote: So you don't need the omega shaped piece that goes around the sway bar bushing? Just the two u-bolts with nuts and the parts that go between the axle and the top of the bushing?
I have practically new bushings with practically new metal retainers on them already for the new sway bar (well, it's used, but it's replacing the tiny one I had before) and also new end links, so I just need the bolts, nuts, and the metal piece that the retainer bolts to the bottom of.
Reply 0
May 23, 2012 | 12:12 AM
Does $23 shipped sound fair for all of it?
Reply 0
Subscribe
