1987 A/C Bracket
Old Mar 28, 2013 | 07:43 AM
twadam's Avatar
1987 A/C Bracket
I'm looking for help, I want to add A/C to my project. I'm running 1987 TPI accessories (No A/C, No P/S), right now. My understanding from researching this, is that the Alt., crank, WP use serpentine, and the A/C uses v-belt. I need to make sure the A/C will fit (I'm also running an electronic throttle). I don't care about the power steering side of things as I will not be running it.
Would anyone be able take a picture of the backside of the A/C unit to see how far in protrudes over the valve cover ? The electronic motor I for the throttle I'm using sticks out over the valve cover (see throttle body here: http://www.eficonnection.com/eficonnection/24x.aspx)
I'm having some issues attaching pictures (maybe I don't have enough posts yet). I will try adding pictures again later.
Thanks for any and all assistance.
If this setup will fit, I will be in the market for the bracket and A/C compressor.
Old Mar 28, 2013 | 09:21 AM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Re: 1987 A/C Bracket
I have an 87 when i get off work i will take some pics of the ac area if youd like.
Old Mar 28, 2013 | 09:49 AM
twadam's Avatar
That would be great. Thanks for the help!
Old Mar 28, 2013 | 06:51 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
If you decide to use the AC, I have everything you would need.
TX-SleeperC5
Feb 24, 2016 01:34 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
timonator
Sep 11, 2015 05:11 PM
scottmoyer
Sep 7, 2015 07:06 PM
