[AZ] Cold start switch
Old Jul 29, 2013 | 10:31 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Cold start switch
Looking to buy Cold Start Switch and connector. New ones are fairly expensive. Anyone have one w/ connector lying around?
Old Aug 12, 2013 | 06:51 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Re: Cold start switch
Are you refering to the 9th injector or cold start injector??
Old Aug 12, 2013 | 06:53 PM
Veaceonee's Avatar
Isn't the 9th injector and Cold Start Injector the same thing? But no, I need the switch that goes in the front of the intake manifold under the throttle body.
Old Aug 12, 2013 | 07:13 PM
Yes those terms are for the same part.
Im not sure what you are refering to as the switch under the throttle body?
Old Aug 12, 2013 | 07:31 PM
Veaceonee's Avatar
It is the one with the brown connector next to the circled one.
Old Aug 12, 2013 | 09:11 PM
Huh??? Never knew that existed?? Looks like a coolant temp sensor.
Old Aug 18, 2013 | 09:19 AM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Do you still need the cold start switch? I'm fairly certain I have one and should be able to cut the connector off my harness.
Old Aug 18, 2013 | 09:20 AM
Veaceonee's Avatar
yes. that would be great. How much shipped to 85730?
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
