[TX] WTB Vortec Heads/TPI conversion/Cam Kit
Old Nov 15, 2013 | 05:39 PM
WoodenRegent's Avatar
Car: 1991 Camaro RS
Engine: 5.8l Aluminum LSX
Axle/Gears: 10 Bolt 3.42 "Spooled"
I have a 350 TBI currently. looking to upgrade to Vortec heads, TPI intake, Harness, ECU, Etc. (might consider HSR for the right price?), and a nice cam to go with. if you have parts? I have money. Let me know what you have? I'm from the DFW area for any locals, btw.
Old Nov 21, 2013 | 10:27 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: WTB Vortec Heads/TPI conversion/Cam Kit
I've got a set of Vortecs but they need to be built. Typical freshing up.....vatting, valve job and possible surface facing. I do have a new set of Manley valves, Comp springs/retainers to go with them. $280 plus ship? Dallas isn't horribly far. Grey Hound shipping might be an option.
Old Nov 21, 2013 | 04:14 PM
Car: 1991 Camaro RS
PM'ed
Old Nov 26, 2013 | 08:47 AM
Harcourt's Avatar
Car: 91 Camaro RS
Engine: 5.0/305
I'm in dfw area and I have several tpi and gm hot cam if your still looking
Old Nov 28, 2013 | 03:41 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I have reconditioned vortecs for $200 and good used vortecs for $150. Plus shipping.
Old Nov 28, 2013 | 04:47 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
i'd be interested in one of those
Old Nov 28, 2013 | 07:21 PM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
I have tpi setup with Auto harness 325 for everything
Old Nov 28, 2013 | 09:22 PM
Engine: that I like
I have an ad here for them, just posted within the last couple days. Both sets still available.
Old Nov 30, 2013 | 09:07 PM
Car: 1991 Camaro RS
PM Sent.
Old Dec 3, 2013 | 09:35 AM
Car: 1991 Camaro RS
I'm looking more into a TPI Setup now if anyone has a complete 90-92 SD TPI setup. that's my main interest right now. I'm swapping from 1991 TBI 350.
Old Dec 3, 2013 | 09:46 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a SD harness and the ECM,...... but no chip, Stock air cleaner too.
Sorry but my other TPI stuff is MAF !
Old Dec 3, 2013 | 10:42 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I have the memcal, send me a pm if interested
Old Mar 24, 2014 | 11:50 AM
Car: 1991 Camaro RS
I'm back, Still looking for a 90-92 SD TPI Setup (Complete Intake, wiring, ecu, etc) and a Heads/Cam setup. let me know what you have? DFW Texas Area.
Old Mar 24, 2014 | 12:05 PM
wesilva's Avatar
Transmission: 200R4
I realize it's not on your short list but just an FYI.... I have a very nice set of Comp Cams Pro-Magnum roller rockers in a 1.52/1.6 combo. They fit nicely under the magnesium Corvette valve covers. I had this combination on my Vortec heads. The valve covers have been milled for clearance and the oil separator removed. The Edelbrock breather now has that function. Not shown is the oil filler cap which I do have. PM is interested.
Attached Thumbnails WTB Vortec Heads/TPI conversion/Cam Kit-ccrollerrockers.jpg   WTB Vortec Heads/TPI conversion/Cam Kit-c4valvecover.jpg
Old Mar 24, 2014 | 02:15 PM
John in RI's Avatar
Still got an SD (auto) harness and factory air cleaner,... pretty sure the ECM is gone.
Old Mar 24, 2014 | 04:17 PM
baddawg53's Avatar
I have a brand new never used scoggin dickey vortec tpi lower intake baseplate.
also have a set of new, never used SLP high flow runners.
let me know if any of this interests you...
Old Mar 26, 2014 | 10:10 AM
Car: 1991 Camaro RS
I'm not looking to piece anything together. just looking for the complete TPI intake.
Old Apr 14, 2014 | 08:48 AM
cougar68's Avatar
Car: 1992 Z28
Engine: 5.7L LS6
I have a complete setup from a 1992 z28 that i am doing an ls1 swap in that i would sell.
The complete intake, wiring harness and computer for $450 plus shipping.
It is from a 305 motor.
Old Apr 23, 2014 | 01:41 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I have a complete SDPC lower Vortec intake, SLP ported runners, port matched plenum with stock fuel rails, 24 lb fuel injectors, BBK adjustable fuel pressure regulator. Let me know if you are interested.
Kevin
Old Feb 20, 2017 | 03:35 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I know it's an old post but do you still have the SDPC tpi vortec lower intake still for sale and if so how much shipped to 72104. Ended up with some fast burns and I think they require a vortec intake due to the high ports.
Old Mar 14, 2017 | 03:06 PM
freaks87roc's Avatar
Car: 87 Iroc Z
Engine: 350 vortec headed
Axle/Gears: 373
I have a sdpc base plate for vortec heads and tpi . with adjustable fuel pressure regulator. no throttle body.
Just replaced it with stealth ram
Old Mar 14, 2017 | 03:46 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I may be interested in the base plate, if the earlier poster isn't interested.
Old Mar 14, 2017 | 05:23 PM
Car: 87 Iroc Z
Axle/Gears: 373
I still have it and i have not received any other interest in it
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
