[NV] parting 88 firebird with 350 tpi and auto in reno, nv
Car: 92 Camaro
Transmission: 5spd
Axle/Gears: Stock
alright I'm parting a car has complete drivetrain. Interior is mostly stripped but not all of it! I'm planning to keep my short block, headers, and hood.
Has a purplish corbeau driver seat $50
Complete tuned port setup with edelbrock pro-flo manifold and fuel rails. I'm not sure what injectors are in it. Comes with dizzy, ecu, harness everything needed to convert your car $600
rear battery relocation box and wire $50
700r4 trans makes a bearing noise but works fine other than that $100
Forget the casting number but they are 69-70 camaro z-28 heads complete with roller rocker arms $200
anything you need that's not listed just message me and i'll let you know if i have it or not
Car: 92 Camaro
Transmission: 5spd
Axle/Gears: Stock
Re: parting 88 firebird with 350 tpi and auto in reno, nv
trying to add a picture not sure if it's going to work
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Do you have the exhaust rubber hanger in good shape it connects from the back of cat to rubber and part of the side of the trans by two bolts
Please need it asap
