[MA] WTB: 82-84 Firebird V8 tach (or cluster if needed)
Old Apr 18, 2014 | 08:10 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Doing an engine swap on my 83 V6 to a V8. Need the tach to match. Will consider an entire cluster if needed but rather save on shipping!
Let me know.
Old Apr 23, 2014 | 12:39 AM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
Re: WTB: 82-84 Firebird V8 tach (or cluster if needed)
i know where one is. if i end up back at that lot i could grab it.
Old Apr 23, 2014 | 08:47 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Cool, no rush, I'd appreciate it.
Old May 22, 2014 | 07:21 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Bump!
Old May 22, 2014 | 02:34 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
I've got a Tach, and recalibrated speedo from my '83 Firebird.
Speedo is now 150 mph, with label from Porsche, that looks like GM
needle broke off speedo (clumsy me) but otherwise fine
instruments only, as I put electric in my panel, when I went to LS1.
PM if interested- then I will figure out where they are stashed- saw both together a short while ago
Old May 22, 2014 | 03:19 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I've got the cluster out of an '86 TA. Can remove the tach. if it would work.
Old May 22, 2014 | 03:21 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'm not sure... I think it has to be 82-84. Or if not, I think it does to match at least!
Old May 22, 2014 | 04:19 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got an early Firebird Cluster, Not really interested in pulling it apart. I have no way to test this cluster,... havn't owned an 'early Bird' in many years now ! ( The only thing I notice while looking at it was that the little trip odometer re-set **** is missing. )
If your interested just make an offer and post your ZIP code for a shipping quote.
Old May 22, 2014 | 06:25 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
How can you tell if it's a V6 or V8 cluster?
Old May 23, 2014 | 10:17 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Big difference I see is that the v6 tach red-lines higher.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
bjpotter
Oct 4, 2015 07:48 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
usafirebird
Sep 29, 2015 11:58 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
