[AZ] firebird speedo sensor
Old Apr 25, 2014 | 11:46 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Did my trans swap and the electrical pins for the speedo sensor fell out rendering it useless. Does anyone have one lying around they can part with for an 88 700r4? Thanx.
Old Apr 26, 2014 | 01:54 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: firebird speedo sensor
What are your rear gears ( or do you know wha teh speedo gears are ?? )
There are 2 variations of the electric VSS's for an 84-89 automatic. The applicable Speedo Driven gear tooth count is stamped into the VSS as shown below:
Old Apr 27, 2014 | 10:32 PM
Veaceonee's Avatar
I don't know the ratio. My housing is scored up and I can't read the tooth count stamp.
Old Apr 27, 2014 | 10:50 PM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
what color is the gear? tan red...
Old Apr 27, 2014 | 11:00 PM
Veaceonee's Avatar
Honestly, I don't know..The trans shop pulled it and showed it to me. If I can get the one for the smaller gears I can turn it 180 to get it to work?
Old Apr 27, 2014 | 11:14 PM
mygta87's Avatar
digital gauges?
Old Apr 27, 2014 | 11:15 PM
mygta87's Avatar
idk if digital gauges and the analog ones had a different speed sensor
Old Apr 27, 2014 | 11:26 PM
Veaceonee's Avatar
Not digital
Old Apr 28, 2014 | 09:03 AM
TRANSAM82-92's Avatar
Yes they are different/Digital
Old Apr 28, 2014 | 09:04 AM
I have one $30 shipped
Old Apr 28, 2014 | 06:00 PM
Veaceonee's Avatar
Pm sent
Old Apr 30, 2014 | 10:59 AM
John in RI's Avatar
FYI:
My 88 GTA 350 auto has 3.27's and uses a 40-45 tooth VSS.
The only other factory option for that car was a 2.77 (9-Bolt ). That rear will require a DIFFERENT sending unit to accommodate the brown 39-tooth speedo gear.
Check your RPO codes for the "GU?" code to BE SURE of your gear ratio.
( If you've got a 10 bolt then the rear was swapped and all bets are off ! )
+1; Electric speedo gears and analog speedo gears are not the same.
Old Apr 30, 2014 | 04:02 PM
Veaceonee's Avatar
My SPID sticker is gone. I do have the factory 9 bolt rear.
Old Apr 30, 2014 | 04:13 PM
Veaceonee's Avatar
I was told that corvettes of the same year used the same sensor. So, I did a search for that. I found this sensor. http://www.ebay.com/itm/1984-1990-CORVETTE-VEHICLE-SPEED-SENSOR-VSS-25007308-/111340288333?pt=Motors_Car_Truck_Parts_Accessories&hash=item19ec65f94d&vxp=mtr. Doesn't look the same, but will it work?
Jorlain
Aug 24, 2022 05:11 PM
9192camaro
16
Feb 3, 2019 12:21 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
