wtb complete tpi setup
Car: 1989 firebird formula
Im wanting to buy a complete tpi setup for my 89 bird that is currently a tbi. Would like to find in one big package deal everything included including wiring harness or very close to being complete let me know what you have.
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: wtb complete tpi setup
I have everything from a 1991 bird I am parting out complete comes with computer and all the wiring 450.00 shipped
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The best options to match the wiring in your car is to use an 88 or 89 wiring harness. A Camaro harness from those years will be very similar; but only an 88-89 Firebird harness will have the electric speedo wiring included. A swap from any year TBI to FI WILL still require some re-wiring, no matter what year the replacement harness is from !!!
I've got most of an 88 Set-up - but not "everything" you will need. This set-up is $250 + shipping. ( Intake, Plenum, TB, Fuel Rails, Hardware ) All parts were blasted, the fuel rails were coated in primer to prevent rust, the intake was painted silver and the hardware is factory. Not perfect; there's a couple dings in the runners and 1 of the oil baffle bolts snapped,.... but still perfectly useable.
< I've got a few more pics >
These small parts are also included. I think the long crank-case tent tube is included too...... I'd need to pull this intake set-up from storage to be sure.
I should also have some/most of the other TPI stuff you would need available separately from the above parts. (air box, ECM, fuel pump, ect... ) Might also have another set of runners too. The one thing I know I DON'T have right now is a ECM harness.
If you need a shipping quote just send me a PM with your ZIP CODE.
Car: 1986 Monte SS
Engine: 383 Stroker
Transmission: 4 Speed Saginaw
Axle/Gears: 3:73 Eaton Locker
I have a complete TPI setup with harness, including an ECM programed by brian from tuned performance right here on tgo, it has a a burned eprom and motes adapter, set up for no vats,no egr, cold start injector delete, no rev limiter ect.. ready to go, it is disassembled for cleaning but is all there, had this setup on a 74 monte carlo and it ran great, the only thing missing is the coil cover on the plenum, I have the fuel pump too $400.00 shipped to your door
Terrell351
Jun 13, 2021 01:13 PM
