[MI] WTB 58mm tb, 36 lb injectors, hawks sw cat-back
Car: 1990 GTA
Engine: 5.7L TPI SLP Runners Accel 24lb Inj
Transmission: 700R4 Upgraded Internals, Shift Kit
Axle/Gears: Borg Warner 9 Bolt, 3.27 Ratio
I'm looking for:
-BBK, TPIS, or Holley 58mm throttle body
-36 lb fuel injectors ev1 style
-hawks stainlessworks catback system
-full set of ground control weight jacks "agressive" version
also need the trim piece that covers the rear edge of the headliner in tan if anyone has a good one
Engine: 4++,350 & 305 CIs
Re: WTB 58mm tb, 36 lb injectors, hawks sw cat-back
I have a 58 mm t-body but its for 85-88 I'm guessing its for your 90?
Car: 1990 GTA
yeah its for my 90, although i've been debating using an lt1 tb. i'm using the eficonnection front cover and 0411 ecm for this build, w/ TPIS mini ram
Car: 1990 GTA
manufacturer and mileage?
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Car: 1990 GTA
looking for something a little less mileage but thanks for responding
Car: 1990 GTA
We can help you with a set of 36lb Bosch lll injectors, flow tested and matched. New orings and screens. If interested please pm or give us a call at the shop.
516-442-4707. We open at 9am NY time
Car: 1988 Iroc Z
Engine: 5.7
Axle/Gears: 9 bolt 2.77
Hi, I have a lingenfelter 58mm TB and it currently has the '89 and newer throttle linkage on it but I have an '85-'88 linkage as well if you should need it. It doesn't have an IAC housing, anyhow if you're interested you can give me a call at (818)292-3309 and I can send you some pictures. My name is Adan.
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
