[FL] 5 speed 91-92 speed density harness
Car: 1992 Camaro RS
Engine: 5.0 liter v8
Transmission: t5
I really need a 5 speed engine harness and if possible the body harness as well I finally diagnosed my car to wiring problems, it's a rat nest so please someone have this.
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: 5 speed 91-92 speed density harness
I have a painless stand alone TPI harness. Never used, just been out of the box and sitting on the shelf.
Car: 1992 Z28
Engine: 383
the engine harness for tpi is all the same auto or manual. The body harness is what is different from auto to t5.
Car: 1992 Camaro RS
Transmission: t5
the auto harness has a tcc lock up and no reverse light plug, body harness has no neutral safety switch hook up and the hatch motor wiring is a little different. i can make either work but id prefer a factory 5 speed harness
Car: 89 Camaro RS
Transmission: 5 Speed
I have a harness from a 91, someone cut it but could but soldered back together. It's a 5 speed harness. I'd sell it for 25 plus shipping
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Are you still looking? I have a stock engine and body harness from a 91 Formula TPI 5 speed.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Nobody seemed to mention it, but I think it highly possible he needs one for a TBI engine
if he even still needs it?
Car: 1988 g92,j65,mm5,dx3 convertible
Engine: 5.0 tpi
Transmission: T5 world class
Axle/Gears: 9 bolt 345 australian disc posi
I have one it's from a 1991 ta tpi 5 speed car wasn't going to sell but what would you pay for it and you are talking about the complete under dash harness correct let me know
