[CO] Need a stock LB9 305 roller cam for a friend's project
Old Aug 2, 2018 | 10:39 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Need a stock LB9 305 roller cam for a friend's project. He is converting a roller block shop truck from flat tappet to roller. If you are familiar, the cam is known as the GM
10088155 Hyd. ROLLER - 179/194 - .350/.384 - 109* - 86-92 LB9 TPI 5.0 Auto, 88-92 LB9 5.0 T5
Yes he knows that there are a dozen other options. He is adamant that this is the cam he wants because he doesn't want to do any tuning at all.
Old Aug 2, 2018 | 10:44 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Need a stock LB9 305 roller cam for a friend's project
I Have one...$75 +sh
Old Aug 2, 2018 | 10:17 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
I may have one, let me check.
Old Aug 3, 2018 | 10:47 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a used one from a 90-92 350; pulled it out of a stock engine during a Cam/Heads swap. I don't KNOW the year of the motor (IIRC the car was a 91 ) or how many miles are on it. Here's a couple pictures I took it before it was coated with Cam-Lube, stuffed in the bag, and placed in storage: pretty sure the PN is 10111773.
$50 + shipping. If your interested just post your ZIP code for a shipping quote. Once I know your ZIP I'll pull the Cam out, get some shipping quotes then I'll update this post with that info.
Old Nov 14, 2018 | 04:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I already have a 773. I need a 155.
Old Nov 14, 2018 | 04:48 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a 91 305 tpi trans am engine I could pull the cam out of.
Old Nov 14, 2018 | 04:50 PM
Dyno Don's Avatar
I still have one/
algershick
Jan 1, 2012 06:32 PM
danielmonster
Jan 6, 2008 03:10 AM
dyeager535
Oct 23, 2003 04:01 PM
kane91z
Jan 5, 2003 08:39 AM
redbird_400
Sep 25, 2001 10:01 PM
