89 to 02 rear brake line brackets
Subscribe
Jan 2, 2019 | 11:37 AM
Anyone got some of these off an old rear they would part with? The brake line brackets that bolt to the rear.
Reply 0
Jan 2, 2019 | 07:30 PM
Re: 89 to 02 rear brake line brackets
The ones welded on the rear, where both lines go through? Or something different ?
Reply 0
Jan 2, 2019 | 08:24 PM
Check with firebirddude142. He is parting out a few cars and was great when I needed spindles. He might have what you need.
Reply 0
Jan 2, 2019 | 08:36 PM
Welded? Yep, the ones bolted to the rear that the brake lines go through. I have the passenger side. Found it this evening. I just need the driver side.
Reply 0
Jan 2, 2019 | 08:41 PM
It looks like your talking about the support that bolts to the LCA bracket and holds the transition from the solid line to the flex line? If that's the case, I built my own out of some thin angle iron. I actually made the left and right sides the same so I could use the same flexible brake line from the support to the caliper left and right. Didn't take much really but I did have one to use as a template (right side IIRC). I just reversed the pattern to make the opposite side.
Reply 0
Jan 4, 2019 | 11:46 AM
Quote: Check with firebirddude142. He is parting out a few cars and was great when I needed spindles. He might have what you need.
indeed i do have a rear end with those brackets text me 6128602513
thanks Lurbie
Reply 0
Subscribe
