WTB: serpentine brackets
Old Apr 30, 2019 | 12:29 PM
Cadmaro's Avatar
Car: 85 Camaro
Engine: Cadillac 500
Transmission: TH400
Axle/Gears: 9 bolt
Looking for the brackets and supports to convert my 1985 trans am to a serpentine setup. If the price is right, I'd like alt, a/c and p/s pump too
Old Apr 30, 2019 | 04:03 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: WTB: serpentine brackets
I've got a full serpentine set-up - everything but the water pump - but shipping it to you will cost a ridiculous amount ( This stuff is heavy !! ) If you can't find anything local and are OK with the high cost of shipping this stuff - send me a PM that includes your ZIP code.
Old Apr 30, 2019 | 04:17 PM
Cadmaro's Avatar
Car: 85 Camaro
Transmission: TH400
Axle/Gears: 9 bolt
Pm sent
Old May 8, 2019 | 11:41 AM
bloodhound1's Avatar
Still looking for serpentine brackets?
Old May 8, 2019 | 11:49 AM
Cadmaro's Avatar
Car: 85 Camaro
Transmission: TH400
Axle/Gears: 9 bolt
I picked up a full accessory drive off a 91 Camaro at the pick a part salvage but I still need the braces
Old May 8, 2019 | 03:06 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
which braces? I should have all of them
Henry
Old May 8, 2019 | 03:36 PM
Cadmaro's Avatar
Car: 85 Camaro
Transmission: TH400
Axle/Gears: 9 bolt
The ones that go from the back of the brackets back to the manifolds. Should be a few of them kinda like these
Old May 8, 2019 | 05:49 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
So you want the entire set then?
Old May 11, 2019 | 01:15 PM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
I’ve got it all pm or text me my number is(612) 860-2513
Old May 21, 2019 | 07:30 PM
Cadmaro's Avatar
Car: 85 Camaro
Transmission: TH400
Axle/Gears: 9 bolt
I have decided to build my own bracing because I'm not sure how well they will work with my headers. I will post up a separate thread when I do so.
rainmkr
Apr 10, 2011 11:58 AM
devinscout
Dec 29, 2010 05:50 PM
TheScaryOne
Aug 21, 2008 07:37 PM
svgould
Feb 13, 2007 06:03 PM
