[MI] Want to Buy 3.08 or 3.23 10 Bolt Rear End
Car: '87 Camaro
Engine: 4.3L V6
Axle/Gears: 3.08
I'm looking for a 10 bolt with either 3.08 or 3.23 gears. It should be mostly complete (gears, diff, cover, axles, backing plates) the more complete the better though. Drum brakes and open diff is fine, Torsen would be a bonus, but I'll also consider a clutch type posi if the price is right. 28 spline (88 or newer) greatly preferred.
Thanks!
Thanks!
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
Re: Want to Buy 3.08 or 3.23 10 Bolt Rear End
Thanks!
Thanks!
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Thanks!
Thanks!
Car: '87 Camaro
Engine: 4.3L V6
Axle/Gears: 3.08
I just want to bump this thread as I'm still looking for a rear end. I've had some things come up but finally have time to get back to this.
I've decided on a 3.08 ratio, 28 spline still preferred but not required. Any brake setup is fine. Thanks!
Car: 02 UltraZ, 85 Z28, 98 WS6, 86 Vette
Engine: LS1, SBC 383, LS6, LS2, LQ9
Transmission: T-56, TH400, 4L60E,
Axle/Gears: 3.42s, 3.73s, 4.10s
If you have a guy in your area that parts lsx cars out... I highly recommend finding a rear end from a 98-02 t56 car as they came with 3.42 gears and you'll have amazing disc brakes via 45mm piston aluminum PBR brand caliper. Just would need to buy the kit for the parking brakes. Best upgrade for under $400 and nailing 2 birds with 1 stone.
SlashXIII
Jan 26, 2012 03:14 PM
1983camaro55199
Jul 20, 2009 07:05 AM
