[FL] Looking for six bolt 4l60e tail shaft housing with torque arm mount
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Like a fool, I forgot to grab one from the 02 my local pick and pull had and by the time i got back it was crushed. So, trying to find one. If the bushings/seal are wiped that's even better. Mocking up a Speedo drive setup in my non torque arm tailshaft soni can perfect the measurements for my swap.
Car: 1984 T/A
Engine: LQ4
Re: Looking for six bolt 4l60e tail shaft housing with torque arm mount
If you use the holley/jhooker crossmember you dont need it. has the torque arm mount on the crossmember itself.
Engine: 5.0
I appreciate the insight. If I can't find one by the time the car is built I'll go that route. The tailshaft housing shouldn't be more than $50, so just trying to avoid unnecessary costs in the build at the moment. But if all else fails, that's a good option.
Engine: 5.0
Found one at a pick and pull while out of town on business.
bryanwood74
Mar 9, 2016 09:34 AM
five7kid
Jul 4, 2013 07:54 PM
