Adding AC back into my car, I have a 350 SBC long water pump setup and V belts with OEM style compressor that needs to be mounted on the driver side. Looking for a stock setup bracket that I can strip and refinish, thanks!
Do you still have all the other brackets and just need the 1 or 2 for the AC compressor?
BTW, I do know that a Monte Carlo SS from the same years uses the same setup.
Yes, my PS, alternator, and long water pump are all set. Just need the AC brackets. My understanding from what I've seen from other's setups are that there's 4 brackets for a stock PS pump setup (Saginaw style). Good to know about the Monte, maybe I need to search online for that specifically and I'll get luckier
Are you using headers or manifolds?
Headers requires cutting 1 ear off an AC compressor bracket.
I have 2 brackets. One I tried to clearance, the other is cut off.
Here is what I found. Hopefully this is everything you are looking for.
That looks like exactly what I need compared to what I see in photos. I bought a new 4 Seasons R4 compressor so if you could include the two brackets attached to it in those photos I'll need those as well. The compressor itself isn't needed, that should help cut down on shipping costs.
I'm using headers, so either the clearanced or cut bracket is OK with me. I'll need to do the same eventually. I'll take any and all of the hardware you can part with. Thanks again, this REALLY helps me out. Just let me know what you want for the setup.
