Want full tpi set up
Old May 3, 2025 | 07:37 PM
wasteland's Avatar
Looking for a full tpi set up intake harness and pcm will pay shipping id pefer maf system but if came down speed density is OK as well
Old May 4, 2025 | 06:59 AM
Apexauto's Avatar
Re: Want full tpi set up
Hi check this out.And also kindly email me for fast response.
apexautomatic311@gmail.com
Old May 4, 2025 | 07:17 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
This is 100% a scam.
Only buy this if you think it would be more fun than lighting your money on fire and watching it go up in smoke.
Old May 4, 2025 | 08:45 AM
wasteland's Avatar
I usaly avoid accounts that are less then 6 months old lol
Old May 4, 2025 | 09:38 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.thirdgenranch.com/catalog...51c85e8c383d49
Old May 4, 2025 | 12:05 PM
wasteland's Avatar
thanks but I had bad experience with thirdgen ranch
Old May 4, 2025 | 12:31 PM
Engine: Lb9
Transmission: M20
Wasn’t suggesting, just showing this is where the scam pictures are from
Old May 5, 2025 | 05:16 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got most of the TPI stuff, TPI intake and the ECM. (all MAF parts), but I don't have a Wiring harness and no MAF. Most of the TPI stuff has been blasted and the ECMs were recently tested.
You would need to find a harness elsewhere,... but if your interested in the stuff I've got the first thing I'd need to know is: Do you have center-bolt heads ?
Old May 5, 2025 | 05:55 PM
Engine: Lb9
Transmission: M20
I have a new sd harness and ecm as well as a 60102 painless , chips and ecms as well
Old May 6, 2025 | 10:39 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I just put a TPI setup on ebay earlier. I think I have some '730 ECM's with v8 memcals lying around too. I need to start getting rid of this stuff I'll never use.
sum_drummer_16
Sep 16, 2010 02:27 PM
87_355ci_Camaro
Jun 22, 2009 01:14 PM
valencia1z
Jun 16, 2009 11:56 PM
6948ric
Oct 23, 2008 12:40 PM
