went carb no computer do i need to wire my fuel pump up or not??
Old Apr 17, 2002 | 12:20 AM
2ponchos's Avatar
hey just a quick question i put in the 400 and went carb ditched the computer.. got rid of what wires i didnt need. but tonight while getting everything ready to start it up tommorow i forgot that i wasnt sure what to do with the fuel pump.. does the fuel pump run into the fuse box since i do have my fuse box wired up to power do i need to wire the pump up at all or not?? thats all i need thanks
Old Apr 17, 2002 | 05:02 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
you will need to bypass the relay and wire direct to the ignition. I did this between the back seats...others use the relay on the firewall drivers side.
Old Apr 17, 2002 | 07:08 AM
scauffiel's Avatar
I didn't change anything when I went to carb. It's worked perfectly for a year now. However, if you got rid of wires "you didn't need" you may have boned yourself. Dunno.
Steve
Old Apr 17, 2002 | 10:26 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
What were you running before? CC Carb, TPI, TBI? if you were running TBI or TPI you'll need to wire up the fuel pump.
I pulled up my back seats and in the middle there are 3 (?) wires, power, ground, and gauge. I grounded the one wire right to the back of the seats and then ran the power wire to the fuse box.
I'm assuming you have a fuel pressure regulator right? The in-tank pump would mess up your carb and probably catch something on fire if you don't use a fuel pressure regulator to lower the pressure down to 5-7psi....
Old Apr 17, 2002 | 11:18 AM
2ponchos's Avatar
yes i have the mallory regulator.... will the pump run all the time?? shouldi put it on a fuse??
Old Apr 17, 2002 | 04:43 PM
Car: '89 IROC-Z
Yes splice it into the fuse box in a place thats hot when the key is on. The safest way to do it would be to buy a oil pressure saftey switch so that when there is no oil pressure (ie, car isn't running) the pump turns off. So if you get into an accident or something your fuel pump won't continue to dump gas everywhere.
Old Apr 18, 2002 | 03:43 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
i gues i am gonna run into the same prob when i put my carbed 350 in. wut do i need to keep so i don't need to wire up my pump? do i still need to keep the computer in my car? also i don't mind doin that i just wunna get rid of all the wires under the hood so could i just cut all the wires under the hood i don't need and thats it? thanks
Old Apr 19, 2002 | 04:39 AM
Engine: 406
the pump will run all the time.when ignition is on...thus the return line on the afpr...make sure the vent line on the gas tank is clear and open.......
Old Apr 19, 2002 | 07:29 AM
scauffiel's Avatar
If I were you I wouldn't cut jack. Just tuck the wires away so they're out of sight - out of mind. If you just haphazardly start cutting crap you're gonna end up with a horror show that NO ONE here will be able to help you with.
I kept my computer and all of the wiring in place; just tucking it away. I didn't have to wire my fuel pump differently, it works just fine without ANY work at all.
My two cents,
Steve
Old Apr 20, 2002 | 04:11 AM
Engine: 406
seems funny how some pumps will run and some wont after the swap
I agree with scauffiel, I wouldnt Cut ontil I m sure I dont need it, I'm in the process of deleting wires now...little by little.
( my pump would prime, but then would not keep running, as the case with alot of swaps)
Old Aug 13, 2002 | 06:43 AM
gtabadboy's Avatar
Wher can you get an oil pressure safety switch and how would i run it. I like the back seat wires idea but I want the pump to turn off when the cars off. How can I hook it up with the oil pressure switch. Also, what ECM wires control the pump. My computer is still in the car and I dont mind reconnecting some of the wires so that I dont have to bypass the pump or rewire it. the first time i went from TPI to carb it worked, but now i put a new carb motor in and it doesnt work. i may have cut some wires. Pics are great. Thanks
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
