good for mid 13's??
Old May 15, 2002 | 10:13 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
good for mid 13's??
hey guys i am buildin up a 350 right now that i will hopefully be low 13's with. here is my combo wut kinda horse do u think i will make and wut kinda numbers do u think i will run? ok its a 2-bolt 350 onepiece rear main seal block bored .060 over with world products s/r heads witch are 1.94/1.50 valves, with a comp cams magnum series 230 duration @.050 and 280 advertised with a lift of .480, an edelbrock performer rpm intake, a edelbrock 750 carb, edelbrock tes headers no cat and flowmaster exhaust. Msd 6al ignition box,blaster 3 coil, summit dist., mallory fuel pressure regulator. this will be linked to my 5-speed tranny and a 3.27 posi 9-bolt. wut kinda horse and numbers guys? thanks oh yea any little changes u would do to the ignition because i already have everythign else or just any little things i could do to get a little more. also do u think 1.5 roler rockers would do anything? thanks
Old May 16, 2002 | 01:35 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Port the heads. Install 3.73 gears and get some high traction tires. (drag radials).
With that much cam you'd want to maximize your compression ratio for the available gas octane. You can adjust this by milling the heads and / or using a thin head gasket if nessessary.
Old May 16, 2002 | 05:29 PM
Don_89Iroc's Avatar
get a torque converter if you havent already gotten one
Old May 16, 2002 | 10:55 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Its a 5 speed. Anyway, where can you get a gear for a borg rear? I have never came across one.
Old May 18, 2002 | 01:57 AM
Blackened's Avatar
www.9boltcom.com
TheJoeY88
Dec 31, 2016 07:30 PM
mdtoren
Aug 23, 2015 12:52 PM
g.l.mos
Aug 22, 2015 12:02 AM
mdtoren
Aug 16, 2015 05:45 PM
