v-groove pullies
Old May 18, 2002 | 07:14 AM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
v-groove pullies
Removing power steering,leaving only the water pump and alternator on my 91Z, and would like to switch to v-groove pullies (cheaper belt).Could I use pullies from an earlier 3rd gen? Don`t want to change alt. speed,so I assume I`d need a matched set.Any suggestions appreciated!!
Old May 18, 2002 | 09:35 AM
mod313's Avatar
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
When I did my swap from 2.8 to 400 I used the pulleys from an 82 g2500 van I had laying around. By using the set from a known application you can just get an alt belt that fits that one. Made buying belts very easy. Also, if you use the p/s brackets from that van setup header fit is much easier. You only need about a 3/4" spacer in the front header bolt to attatch upper bracket.
bryaniskoo
Oct 1, 2015 03:18 PM
evilstuie
Sep 24, 2015 02:31 AM
sunbound
Sep 5, 2015 11:52 AM
89_G92_Iroc
Aftermarket Product Review
Nov 23, 2001 02:07 AM
curt86iroc
Aug 7, 2001 12:03 AM
