complete l98 to lt-1 swap, please help
Hi guys, it turn out the 60k mile l98 350 engine i was going to buy was a 305 with 100k miles on it. So i got screwed on that deal. Now my dad found a 96 lt1 with 21k miles on the car today with tranny and fulling harness for $1200. He drove the car that had the engine in the car and sayed it ran great. So what i need answer is a question that has probably been on here 100 times. What do i need to do to change all the l98 components to lt1, is the driveshaft the same size? how hard is it to change all the wirring harnesses? I really dont want to mess with the harnesses because of what a pain in the *** it look like but i guess i will have to do it. If there is a how to on this please send me a link, or if you have personally done this swap please give me some info on it. Thanks alot
Bobby
Bobby
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
well as you know you cant put the tpi on the lt1.and you dont want to mess with the wiring. so i would say go carb. gmpp sells the lt1 carb intake for about $250.00 im doing this conversion now. the lt1 gets good gas milage w/the carb& makes awsome horsepower.as for the tranny & drive shaft will bolt right up. any ????? just e-mail .
Ok stop it right there, WHY, but WHY would you carb it .... just stop posting that all the time ... it's useless to carb it. Just get a el-cheapo 350 instead if you want to carb it ...
Now, you CAN do this swap ... all fuel injection F-body from GM uses the same color codes ... just match up the wires ... it's that simple.
The complicated part is VATS , witch isn't that hard to figure out ...
If you need help about this once you started the swap , there's a ton of guys on this board that can help you.
anyway about the carb...it's
to me .
to me . Member
mat dont get so offensive this broad is full of different opinions. and i post what i want! gm would not make the intake if it was not any good!
Thanks guys, i am just alittle intimidated by having to change the wirring harness. I appriciated the replies. I think i will be getting started on it asap. Painless wirring wants $900 for the swap and they say it REALLY EASY. I dont think i wont to pay $900 for another wirring harness when the engine and tranny are costing me $1200 with the stock harness, what do you guys think?. One more thing. Is the tranny mount different on the 4l60e from the 700r4 i have in my car right now? later
Bob
Bob
Terrell351
Jun 13, 2021 01:13 PM
