406 advice...
406 advice...
I have a 92 RS with the 305 that has pretty much been sitting for the longest..I have finally decided to do something with it.
Ive thought about doing an LT-1 swap but I dunno...sounds like a PITA..I have a 406 block I kinda want to tinker with..Would it be possible to put TPI on it..I really want it to be fuel injected unless it will be too costly or troublesome..Any advice or opinions will be greatly appreciated.
Cory
92 Purple RS collecting dust =(
Cory
Transmission: 4L80E/4L80E
TPI in stock form is going to severely choke a 406. Miniram is a good way to solve that. Figure on PROM work.
"Expensive" is a relative term, I guess. Too expensive for me, but maybe not for you.
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
I love my carbed 400. It is mildly built and is essentially same as when i was still street driving it. It has an old set of ported, etc 461 heads from a 66 L79 327 motor, 10.4:1 comp, solid cam, Demon carb and a few other basic stuff on it. This thing is still pulling hard through traps at 7k rpm. You'll definately like the torque it puts out.
Cost wise, it's relatively cheap too build since so many are doing them. Use a set of 350 rods on it as this will give you a bit more torque. Pistons will cost the same with the 5.7" rods as the 5.565" 400 rods. I ran mine on Sunoco 94 octane fuel when I was still street driving it with no problems, although it now gets a steady diet of VP C12 race gas. Once I get a couple bugs worked out of it the et's will be better but so far it has gone a best of 11.34 @ 118.22 mph with a best short time of 1.500.
Car: '82 Z28
Engine: none!
Originally posted by Astro
A 406 is just a 400 block with a 0.03" over bore. Anyone can correct me if im wrong.
I'd also suggest a carb, but I think everything ought to be carb'd, so I'm biased.
I think that attitude mostly comes from my basic lack of experience with EFI in general and with custom EFI in particular, but if you're in the same boat as I am, I'd recommend the carb even more.
Car: Camaro
Yes, you do have to drill out the steam holes in those heads. Although if I had to have the heads done today it would be cheaper to by a set of Air Flow Research 195 heads and have them angle millled to get the combustion chamber down to 67cc. I just happened to still have these heads on hand and had reworked them a bunch in the 80's.
Well
Im considering buying some Dart II Sportsmans for it.
I think they have the holes(or at least I hope they do) Im somewhat limited on the ammount of money I can spend since Im about to quit my job and go to school for Auto body repair.
I at least wanna get a good start on the motor.
Cory
Cory
TPI 406
there is a guy over at camaroz28.com that has a TPI 406 in his 86 iroc...might shoot him an email and ask about his setup...his name over there is aziroc can find his posts in southwestern F-bodies clubs.. otherwise here is contact info for him...
az iroc info
last time we went to dyno, he was at 399.? rwhp... bad sounding camaro!!
Andy in AZ
az iroc info
Andy in AZ
Car: 86 IROC-Z
Engine: 406
geesh.. i dont visit this place in a month and im missing out on so much. hey andy thanks for the plug in :hail:
my 406 honstly looks like the stock 305 that came in my 86 iroc. i have the orignial TPI setup *well..the look of it* but i have a 58mm t.b., TPIS bigmouth *ported*, TPIS large tube runners *ported*, and the stock plenum *ported* it flowed/flows well over 1000 cfm so air is not an issue *its fuel* they are AFR 195 heads *ported/polished/valvejob, ect..* the only thing is my injectors are killing me. normally 26 lb injectors around 50-52 psi is more then enough fuel. well mine is severly lean. so im going to buy some SVO 30's which is kinda overkill *28 lb injectors is fine if u dont want to add any power adders* but in a year im going to add a 8-10 psi ati procharger.
just FYI if u are going for high hp/tq #'s.. its expensive. specially if u havent had anything else dont ot ur car *ie suspension, tranny, rear end, ect..* i did majority of the stuff before installing the engine so i knewthe car would be safe. right now i prob have about 23-25k into the car. and honestly the only thing killing me *besides injectors* is rims/tires. but i want 2500 rims and 1000 tires.. so its going to be a while till i get those.
my email is falcon978@aol.com email me if u need anything. im sure i still have cam specs and other info on the engine if u need it.
my 406 honstly looks like the stock 305 that came in my 86 iroc. i have the orignial TPI setup *well..the look of it* but i have a 58mm t.b., TPIS bigmouth *ported*, TPIS large tube runners *ported*, and the stock plenum *ported* it flowed/flows well over 1000 cfm so air is not an issue *its fuel* they are AFR 195 heads *ported/polished/valvejob, ect..* the only thing is my injectors are killing me. normally 26 lb injectors around 50-52 psi is more then enough fuel. well mine is severly lean. so im going to buy some SVO 30's which is kinda overkill *28 lb injectors is fine if u dont want to add any power adders* but in a year im going to add a 8-10 psi ati procharger. just FYI if u are going for high hp/tq #'s.. its expensive. specially if u havent had anything else dont ot ur car *ie suspension, tranny, rear end, ect..* i did majority of the stuff before installing the engine so i knewthe car would be safe. right now i prob have about 23-25k into the car. and honestly the only thing killing me *besides injectors* is rims/tires. but i want 2500 rims and 1000 tires.. so its going to be a while till i get those.
Car: 86 IROC-Z
Engine: 406
btw.. cooling is simple.. yet $$
griffan alum nascar radiator *500-600*
alum waterpump *100'ish*
1 big *** fan *$100'ish*
i live in phoenix az.. yea the 120 in the summer time state. so cooling for me may not be as crutial for u.. but i can run the snot out of the engine for over an hour.. and it doesnt get about 140 degreess. normal driving/traffic it stays around 120-130 .
Hmmm
Well Im almost for sure gonna do it carbed..only a few more weeks till I will have the money to get started...So far this is the list(maybe) Sportsman II heads,Lunati cam-246 duration @.050 .515/.515 lift,Edelbrock Air gap intake,carb not sure..either edelbrock or speed demon...5.7 rods, TH 350 tranny, I have another rear end sitting in my buddies shop...I forgot the specifics on it since I havent messed with it much but I'll get them,Im gonan do a cage and sfc's,ditch the 16 inch factory wheels in favor if welds 15x8s in back 15x5s in front...Anything new comes to mind or anything I forgot I'll repost...Sorry for the unorginized ramble..
Cory
92 RS not dusty now since it rained=)
Cory
Car: 86 IROC-Z
Engine: 406
do u suscribe to chevy high performance? if so they did like 10 engine build-ups a few months ago. and there was 1 awesome 406 in there *carbed*. if u dont have it ill find it and either scan/type u the specs on it. but the #'s were up there.
my car right now looks like traler trash cause i just got into an accident. it was viper red. but not it has a primer black hood, orange fender, and the red body. the car is fine.. just bent an axle in the back. i think i may have bent the frame some because the hood/rear window dont close the same anymore. but i cant find where the bend is at *damn my 4k in suspension mods.. now i cant find where its messed up* fortunatly its not bad.. it just pulls to the left alittle *nothing a little spring cutting cant fix* but a new hood *iroc daytona hood* is comming soon and the paintjob should be here around the new year .
Car: 86 IROC-Z
Engine: 406
btw.. y a th350 tranny? is this a drag only car? i have a 700r4 hooked up to this 406. granted the 700r4 is modified to handle it... and i can decent gas milage *18-20 city 24-25 highway*
Az..
If you dont mind Id like to see those specs...Well mines is a Ford purple right now but soon it will be primered down then painted this fall a dark blue...cops are hell on the purple..pull me over all the damn time(when I was driving it that is) As far as the TH350...I cant pick one up and get it built to handle the motor for far less than the 700r4...I will drive it on the street but I have a daily driver(88 grand prix aka The *****)and I drive my Girlfriends car(95 v6 camaro) so I will be ok I hope...Just in case I want to ponder it..what do you have done to your tranny...and I am kinda worried about the rear...I will go look at the one I have at the shop and get the specifics so somebody can tell me about it...
Cory
92 RS Not Collecting dust anymore since it rained
Cory
Car: 86 IROC-Z
Engine: 406
id love to tell u whats all done on the tranny.. but i have no clue.. there is a shop here in AZ that does work on only 82-02 f-bodies. and they know there ****. but for like $1000 he makes it where the 700r4 can handle anything u dish out. this is also the same place that has done everything to the car *lol im more of a moblie business card for him * when i get home.. well more when i get home.. and after i wake up &*around 2 pm* ill get those stats to you. im here at work for another 90 mins *time isnt flying damn it * u may want to look at *which i wish i did* is see how much more it would cost to make sbc 427. well how much more can u spend. they are just awesome engine. but they are very $$ to make. *my engine cost me $10k'sh *including labor* and the 427 would have been more like 13-15k'ish. i have a 10 bolt in my car right now.. again.. he did some major work to it and said it can handle the power now.. but if i add my supercharger he would suggest a 12 bolt or 9 bolt.
Good deal
Thanks a lot man...Im just doing a lil at a time since its easier for me(an my girlfriend) that way. Yeah the 427sb is pricey...Im pretty much gonna build mine like a buddy of mine built for his nova a while back..it went 11.88 in the 1/4..not sure about speed and all that, but it had very little after market parts on it...I am going to use more aftermarket parts on mine. I hope I dont drive myself nuts with all the thinking I am doing on this.
Cory
Cory
Car: 86 IROC-Z
Engine: 406
well dont loose sleep over this. i finally got soem decent "im saying this loosely" rubber on the back tires so once the new injectors go in im going to run it at the track. but i know its good for high 11's.
Car: 86 IROC-Z
Engine: 406
ok here is the stats on thiws 406 *520 hp 480 tq*
displacement 406 cu in 4.155x3.73
10:1-10.5:1 comp w/ alum heads
heads: AFR alum 210cc -10std or sart alum pro 1 215cc or
world production iron motwon 220 cc
cam: crane powermax roller
244/252 degreese @ .050, .543/.0561, 112* l.s.
intake: edelbrkck victor jr PN 2975, super victor pn 2925
carbL holley 750 pn 0-4779 or speed demon 750 pn 1402010
headers: headman, hooker, dunomax... 1 3/4 or 1 7/8
exaust. flwomastrer 3 inch mufflers
Car: 86 IROC-Z
Engine: 406
no problem.. ill let u know. but i think the only fun part is watching me make this high 11 sec car do 14's the first time since i never been to the track
Car: Camaro
I never had any trouble with my 400 getting hot on street even during the summer months. If anything, it ran too cool. I used the stock V8 radiator with a Wieind aluminum water pump and a gutted out stock t-stat. I already had the lower air deflector under the rad support on it before this. On 65* and cooler days it was always 155* and on hot summer days it never got over 170*. Total money invested was just the cost of the alum water pump ($125) and a used radiator($20).
news...
Ok I just found out that the block is .40 0ver instead of .30..so that would make it? 408 maybe? And about the rear...The guy told me its a Corporate 8/5 10 bolt...anyone that knows anything about me..let me know=) And I hope I dont make anyone mad by asking rear end questions on a motor swap board but I already have people helping me and they may not be of help if they dont know where Im posting so forgive me...
Im probably ordering pistons and 5.7 rods friday so I can get this project in motion..
Cory
Cory
C409
Sep 23, 2015 04:30 PM
