350 with 2 bolt mains
Old May 29, 2002 | 04:42 PM
Mr82transam's Avatar
How much power can a 350 block with 2 bolt mains handle? The crank and other stuff will be forged parts.
Old May 29, 2002 | 06:42 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
your 2bolt mains are fine, as long as your not gonna get real radical, blowers, high compression, etc, You should pump out 400 ponies just fine with your 2 bolt
Old May 30, 2002 | 01:48 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Splay the maincaps if your really worried, but I think you could take 400-500 horsepower in standard form. As said above, don't push it with boost or nitrous, or high rpm, and you'll be fine.
Old May 30, 2002 | 12:09 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Could you define "not pushing it with boost"? Are you talking about 15+ or 8 to 10 PSI?
Reddeath210
Oct 6, 2015 08:20 AM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
