3.1 to 5.7
Transmission: 4L80E/4L80E
This is the oft-discussed "V6 to V8" swap. It ain't exactly easy, but not impossible, obviously. Look over posts on this forum, the details have been spelled out several times (may have to go back a few months).
About the only thing non-typical about your situation is being sure to use a 153-tooth 2-piece rear main seal flexplate. A part intended for '82-85 3rd-gen V8 will do the trick.
Question for you, though: Exactly what TH700 have you had "rebuilt for racing"? Your 3.1 tranny won't work on a V8.
Had a better idea recently. Does anyone know where i can find a wrecked IROC in the SO CAL area. I read somewhere on the internet that a guy did a motor/dash swap out of an IROC into his SC. It seems easier and cheaper. thnx
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Originally posted by trebor_86
It was the stock tranny that i rebuilt. the guy that sold the engine to me said it would work. (sigh)
he told you a load of
blackz281le
Jan 11, 2016 07:51 AM
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
